Old 06-28-2010, 05:20 PM   #1
hdcruzer's Avatar
Default Removing Motor mounts?
Whats the secret to removing motor mounts ? I got 2 to break loose but the other 2 wont budge. Ive tried everthing liquid wrench, tapping , w-d 40 nothing seems to free them up. Ive even tried heating them with a hair drier and that didnt work either. Please help.....
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 06-28-2010, 05:24 PM   #2
808gx7r's Avatar
from the chassis or the engine blocks?
for chassis. use a hair dryer... (not a heat gun)
sit it almost on-top of the mounts, to the side so it's lying against the chassis side guards.
leave it on high for 10-15 minutes.
flip it over. get a hex DRIVER, and hit the top of drive reasonably hard with a set of flat sided pliers(not a hammer..)
should loosen up
DONT HEAT FROM CHASSIS PLATE SIDE... more luck heating the actual mounts.
for getting engine block off mounts. heat the mounts again as above.
sit the engine down aganst something. grab a piece of wood or as such, put it against the mounts and lightly tap the piece of wood with something.
it will loosen them.
i just had this problem with my xray mounts on my engine. works a charm
808gx7r is offline   Reply With Quote
Old 06-28-2010, 05:24 PM   #3
jammin32j's Avatar
Sometimes smacking the back of the wrench with a hammer will get them loose. If that dont work just cut a slot in the bolt and use a flat head screw driver.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 06-28-2010, 05:26 PM   #4
jammin32j's Avatar
Oh yeah do this on the chassis side. If it is on the engine side sometimes you can use vise grips to break those loose.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 05:29 PM   #5
dash riprock's Avatar
I have a small butane torch that I use to heat up the motor mount screws.Just make sure the chassis is clean of any spilled fuel!!Heat up the mounts where the screws thread into not the head of the screw.
Tony Hopcraft
Losi 8ight-T 2.0 Losi 8ight 2.0 Losi Mini-Late Model,Losi L8ight Model
Hobby Revolution Team Driver
dash riprock is offline   Reply With Quote
Old 06-28-2010, 06:01 PM   #6
hdcruzer's Avatar
Okay Ive tried all your guys suggestions except cutting a slot and they still wont break loose. This is really pissing me off...........
Coldfusion Fuel
Henchman Racing
Old 06-28-2010, 06:12 PM   #7
jammin32j's Avatar
On mine I ended up going to Home Depot and buying flat headed bolts that fit so I never have that problem anymore. Just slot them to get them out and buy new ones that are all ready slotted to replace them with.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 06:16 PM   #8
hdcruzer's Avatar
I have some stainless steel hex screws that Im gonna put back in. The reason they get so stuck in there is because they rust. The stainless and a drop of locktite and Ill never have this problem again.......
Coldfusion Fuel
Henchman Racing
Old 06-28-2010, 06:18 PM   #9
jammin32j's Avatar
Stainless steel will strip easer than the stock ones will.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 06:20 PM   #10
jammin32j's Avatar
Im sure some people will disagree with me but I do not locktite my chassis bolts for my engine mount. They are hard enough as it is to get them back out.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 06:21 PM   #11
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Still no answer as to which side these bolts are on??? What kind of driver are you trying to use?? We need some more info to help you further.
I personally have a Husky ratcheting driver that bends at a 90* angle. I use a short hex bit(not the RC speed tips... Like a normal hex bit) of the right size in the driver. With it locked in the 90* position you get a whole lot of torque. If the hex head is not stripped out and it is strong enough, this method will get the screws out without too much effort. Just be careful, it will also strip the heads out easily if you aren't careful. Make sure the bit is all the way in the screw. Even use a small hammer to tap the bit into the screw head. It should bust them free pretty easily.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-28-2010, 06:25 PM   #12
jammin32j's Avatar
That works too but make sure you wear gloves. I had one of those drivers break on me and cut the crap out of my hand.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 06:29 PM   #13
Another tip too when dealing with loctight or a seized screw is to actually try tightening it a bit to break it free before you try to loosen it. Might be worth a shot.
-Koby Kubrin-
Old 06-28-2010, 06:32 PM   #14
jammin32j's Avatar
I will have to try that next time. Makes sense.
VP Pro, Agama
Jeremy Davis
Old 06-28-2010, 06:46 PM   #15
one piece mount or two? if it's a 2 piece, as long as you get one of them out you can move the mount to loosen the other screw.
if it's a one piece, just slot it with a dremmel and be done with it.
If that does not work, at that point i would take a drill and drill out the head to break it and get some pliers and unscrew it once the mount is off.
also i would never use lock tite on engine mount screws. I check them before every run and they are never even remotely loose. As for stainless screws, throw them in the trash because that is where they belong.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Help with removing engine mounts helgso Nitro Off-Road 25 07-01-2009 11:23 AM
8 rtr w/ mach 427, removing roto start for bump start Hitman Racing 1 Nitro Off-Road 7 03-25-2009 11:10 AM
removing damaged screws 32819toon Nitro On-Road 11 07-28-2007 04:51 AM
