How to rotate fuel connection on carb
The fuel connection on my carb is facing the wrong direction for what I need. The exploded view for my engine is not very clear but it seems the only way to loosen it is to back the high speed needle out. Is this correct? I was a little afraid to do this as I wasn't sure if this would damage or do anything negative to the carb. It's a Werks B5 .21 if that is worth noting.
Loosen the brass part of the HSN, turn the inlet where you want it and tighten it back. If you look you will see that at the bottom of the brass sleeve, you can put a wrench on it. Backing out the needle itself, will not allow you to turn the inlet.
See the HEX area toward the base of the HSN? Loosen that just a little, and the nipple will rotate.. Move it where you want it, and retighten.. DO NOT OVER TIGHTEN!!!! it can break or case leaks.. Just try to remember how tight it was when you loosened it, and put it back the same.. Use a deep well socket if you have one, if not use the boxed end of a wrench..
