Old 06-27-2010, 08:44 AM   #16
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by didrace View Post
The last two races i lost the competition due to my engine and clutch. Its been two years now i am running the o.s vspec but not the speed. I used to run the stock kyosho aluminium clutch setup both on my st-rr and mp9 but i had quite a few bearing failures, so i then switch to the mip buggy clutch and i was suprised how smooth and flowless is oparating but the last two races the springs loose and on the accelaration the engine was struggling. I also have one vspec that needs rebuilding so i came here to ask which is the best engine, and the best pipe for that engine and which is the most popular clutch setup. When i say best i mean first of all reliable and then fast.. Cause i dont want an engine than will run for 4-5 gallons and then i will need a rebuild. But at the same time i need the engine to be powerfull enough so that i will do the long jumps and also fast enough on the straights.
as soon as i get enough help i have 400 euros ready and if i need more next week i will have more for buying the what you guys recomend.
Btw the engine will be running either on an st-rr,xray xb808,mp9. but if its not useable foor a truggy then no problem.
Thanks.
Engines run hard and need maintenance too. Bearigs only last so long and eventually need to be replaced. If toungakencare of them most p/s will go 8+ gallons. I had a speed engine that had 14+ gallons on the carb, case, and crank qnd it only bley because the crank pin wore. It went through 1 p/s/r change and a few bearings. I think some of the longest lasting engines are the novas. I like os engines personally but I know your frustration. Hopefully os will come out with a new and improved engine that blows the vspec away.
And 400 eurus yo can have any eninge on the market.
I love these type of threads. At the end prob every mfg will be reccomend except rb not many rb users I guess. What I want to know is how does recommending every engine mfg help?? We will see
Old 06-27-2010, 08:45 AM   #17
Zerodefect's Avatar
I can only tune 7 ports! And if I'm going to commit to the headaches of nitro 2stroke I want crazy smilie power.
RB WS9
Novarossi FMS
I use OS plugs in both even though it's not really good for the head buttons. I can't seem to tune Od or NR plugs for some reason?
I'd love to play with the OS .28xz in a truggy some more, but they don't seem to last too long.
Zerodefect is offline   Reply With Quote
Old 06-27-2010, 11:06 AM   #18
houston's Avatar
Trader Rating: 91 (100%+)
Anything novarossi
Buggy - plus4 , 9901ss/41005
Truggy - p5xlt "tuned" , 2084ss/41021
Other choices are , toro nero , FMS and apparently there is a new econo 5 port . I will keep ya posted
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-28-2010, 06:51 AM   #19
didrace's Avatar
No one is recomending O>S.. hahaha
I think O.S are overpriced..
I never used wercks or Nova but it seems from the posts here these engines are compatible in the performance with o.s and they are cheaper.
didrace is offline   Reply With Quote
Old 06-28-2010, 07:44 AM   #20
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
get a engine that has USABLE power.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 06-28-2010, 10:29 AM   #21
ScottyM's Avatar
Trader Rating: 27 (100%+)
I'll 2nd that..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 06-28-2010, 10:31 AM   #22
didrace's Avatar
Trevor which one do you recomend?
Old 06-28-2010, 10:34 AM   #23
ScottyM's Avatar
With A-main selling V-specs at $250 they are affordable enough, but are they worth it? The metalorgy ont he crank seems to be subpar..
I'm currently torn between Werks or Alpha Plus.. I'm leaning more toward the Werks because I already have the pipes for it. But if I had to buy both engines and pipe I would prolly go with an Alpha.. BUt don't think you would go wrong with either choice..
I've seen both run and both scream, I've seen alot more Werks engines then I haev Alphas, which is another deciding factor for me.. None of them have had any troubles, they get good enough mileage, and make awesome power..
Scott Musgrave
Old 06-28-2010, 10:34 AM   #24
Trader Rating: 12 (93%+)
get the clockwork mod jl .21. i got mine and its awsome, its smooth and has a whole lot of power!
rcdude236 is offline   Reply With Quote
Old 06-28-2010, 10:39 AM   #25
if I were to pick one engine, it would be a Novarossi 21-4 Team with a 9853ss and a 41005.....butter smooth with gobs of usable power delivery when you need it........im trying a OS speed next time at the track.
SmacTrac
Old 06-28-2010, 10:50 AM   #26
ScottyM's Avatar
If it did't cost so much to get into one it would be my choice.
Scott Musgrave
Old 06-28-2010, 01:04 PM   #27
RC-ZOMBIE's Avatar
Werks B6 same power delivery and alot cheaper
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 06-28-2010, 05:55 PM   #28
MAGPIE-121's Avatar
this is what u need : http://answer-rcusa.com/zencart/inde...roducts_id=372
check out the dyno : http://www.youtube.com/watch?v=nPxpT...layer_embedded
"JQ's THE CAR" GODZILLA .21 2072 pipe-KO EX-10 Helios-Spektrum pro-Savox 1268s
"JQ's THE CAR II" MG66 moded 2072 pipe-KO EX-10 Helios Spektrum pro-Hitec 7955s
ALL RUN ON MMI- NEO+ 25% using Competition Heat-Ascendancy Effortless Clutches-TKO clutch bearings (Massive Mark - Nitro Addicts Australia)
MAGPIE-121 is offline   Reply With Quote
Old 06-28-2010, 06:18 PM   #29
houston's Avatar
that my friend is the trick
novarossi has great useable power
Old 06-28-2010, 06:20 PM   #30
houston's Avatar
novarossi plus 21-4 buggy (tuned) 275$
9901ss / 41005 or if you like alot of torque use 41021
