Old 06-25-2010, 05:33 AM   #1
morocho1979's Avatar
Default Bearing hyper 9
Hi i have a frind who race with hyper 9 and the bearing of the diff fail every race what i have to do to repair this i have to buy bearing everyrace ?? or have a tip for that trouble thx
Juan (morocho) MBX6R-us
Caracas,Venezuela
www.venezuela-rc.com
http://www.cocinasdada.com
http://www.race-monitor.com
morocho1979 is offline   Reply With Quote
Old 06-25-2010, 11:29 AM   #2
Dozey83's Avatar
which diff is it? and which bearing?
i have had one inner diff pinion fail on me in over 6 months of running, and it has been the same bearing from day one, (i had the car 2nd hand and im pretty sure it wasnt a new bearing then!)
it is not usual for this amount of bearing failures on ANY car! so it must be being caused by something else, have you checked the diff housing for faults, any looseness in the mesh on the diff pinion, last thing, what bearings are you using? are they sealed or shielded? what make are they???
hope that is of some use! if you give more info on the bearings then im sure myself and others can help further.
Dozey83 is offline   Reply With Quote
Old 06-28-2010, 05:48 AM   #3
The trouble is with the rear diff the pinion bearing and side of the diff he change the diff case he use sealed bearing avid is the firt version of the hyper 9
Caracas,Venezuela
Old 06-28-2010, 05:56 AM   #4
Replace the holder, if the holder is the case, replace that......sounds like you have a bearing holder that allowing the bearing to move (wobble) in that spot....
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-28-2010, 09:27 AM   #5
We change the holder a lot of times 6 times and the bearing 8x14 and the failure persist can exist the posibilities of the first version of hyper 9 came with troubles on the rear cases. the team dont use anymore hyper for that trouble.
well thx for the reply's
Caracas,Venezuela
hobao hyper 9 or hongnor x2 buggy vyt666 Nitro Off-Road 40 03-22-2009 08:05 PM
