Old 06-24-2010, 06:15 PM   #1
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Default piston to tight in sleave?
i got a v spec that needed bearing i replaced bearings all is good.put the crank in and then piston n sleave the piston is so tight in the sleave it will not turn over or get to top dead center any help would be nice
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 06-24-2010, 06:22 PM   #2
Default pics
the p/s on left is the one out of my v spec one on right is the one in ?
piston to tight in sleave?-slash-073.jpg   piston to tight in sleave?-slash-074.jpg   piston to tight in sleave?-slash-075.jpg   piston to tight in sleave?-slash-076.jpg
Old 06-24-2010, 06:28 PM   #3
8&stuff's Avatar
Trader Rating: 55 (100%+)
heat engine up to about 200 degrees. then make sure your starter box batt is fully charged. and crank'er over. also make sure you have some after run oil in there to lube internals up
8&stuff is offline   Reply With Quote
Old 06-24-2010, 06:32 PM   #4
if you don't oil the liner and piston it will barely go in.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-24-2010, 06:35 PM   #5
22Racer's Avatar
Trader Rating: 67 (100%+)
The piston and sleeve that are too tight are out of a running engine? I don't think I would force it, could end up ruining it. I charge the same to loosen a sleeve as I do to repinch it. $15.00 return shipping included.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 06-24-2010, 06:43 PM   #6
the guy said it ran great and that was for shure the p/s that was in it i have tried heating it up no go still tight ime afraid if i try to start it it will snap a rod or something
Old 06-24-2010, 06:46 PM   #7
the piston i put a little after run oil on it befor sliding the sleave in to the block slides in real nice just wnt turn ove or even close to top dead center
Old 06-24-2010, 06:48 PM   #8
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
are u heating it properly ie 200f or 100c and all around the motor and keeping it hot with a beer cossie or foil
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 06-24-2010, 09:01 PM   #9
Trader Rating: 30 (100%+)
must have been repinched to tight or piston and sleeve from different pairing mixed matched to find tight one just run it heat it up tin foil the head and let it idle a tank then heat cycle the thing it will scream just replace the rod once the metal pinch goes away because it will be hard on the rod being that tight i had nova motor just like that couldnt get it to turn over with flywheel on until got it over 200 deg. broke it in and now it flys
jewn_beef is offline   Reply With Quote
Old 06-24-2010, 09:03 PM   #10
Is it like super tite at the top? Could something have fallen on it and slighty bent the top of the sleeve and make it ovalish? If it was good before u took it out then something went wrong between the time u took it out and put it back in. Did u have it pinched? My guess is the sleeves out of round at the top making it stop.
Matt Piva is offline   Reply With Quote
Old 06-24-2010, 09:52 PM   #11
Double post
Old 06-24-2010, 10:20 PM   #12
Trader Rating: 47 (100%+)
Well it sounds like you screwed up some how, huh?
I think you had better take advantage of Rex's (22racer)
offer to help you out with that engine. Did you use pliers
to remove the sleeve from the case? What did you stick
into the exhaust port to push the sleeve out of the case?
rageworks is offline   Reply With Quote
Old 06-25-2010, 06:39 AM   #13
killabud's Avatar
Make sure the crank is all the way in the block. If its out a little the rod will be a little crooked and it wont turn over.
Tom Ulmer Team FISH-DO
---\\\Kyosho MP9 TKI3///---
\\\Futaba|OS Engines|VP Powermaster///
Baby Car!!!!!!!
killabud is offline   Reply With Quote
Old 06-25-2010, 07:19 AM   #14
Is it only too tight when motor is assembled? Did you not seat the rear bearing all the way?
bacchus is offline   Reply With Quote
Old 06-25-2010, 08:23 AM   #15
Reno's Avatar
Trader Rating: 16 (100%+)
+1 on talking to Rex Welch. He will take care of you.
Rex, I race with Tony Bacon. Did you hear he is now a Mugen Team Driver?
Quite the deal for him.
Steve McClintock
Reno is offline   Reply With Quote
Piston & Sleave Question RCinSC Nitro Off-Road 34 05-21-2009 06:38 AM
