Old 06-23-2010, 09:55 PM   #1
vti-chris's Avatar
Default Need help with engine problem and fast...
This is a problem encountered on 3 different engines on three different people up to now and we don't know what's causing it.
We are not noobs on tuning so we know the "basics".
Engine runs fine with the glow starter on but dies when removed and give it a full throttle.
If it's a blip style full throttle it will die while going to idle.
If it's a WOT to clear the engine it dies before reaching full rpm by dropping rpm and dying.
We all run RB 30% buggy fuel.
Engines are 2x RB WS9 and one Reedy 121VR.
We tried tuning it...no success.
Tried different plugs...nothing.
Tried other engines on the same car and they work...so it's not the fuel tank, clutch or pipe.
Any suggestions would be appreciated.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 06-23-2010, 09:59 PM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
Check to make sure it's not leaking and check the carb boot. Then set it back to stock settings and re tune it like it was new. Does it have good compression? How many gallons on it?
Old 06-23-2010, 10:03 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
same batch of fuel?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-23-2010, 10:04 PM   #4
vti-chris's Avatar
Yes it's the same batch.
But others seem to be doing fine...at least only flaming out on the track and not on the starter box!!!!
No leaking or so ever.
Both WS9 have around 4-5 gallons.
The Reedy only has ~3.
We did try the stock setting but nothing seems to fix this.
And it happened so suddenly on all 3 engines that we don't know what to do.
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 06-23-2010, 10:09 PM   #5
houston's Avatar
once again chris , same batch of fuel?
try somebody elses bottle of fuel
Old 06-23-2010, 10:09 PM   #6
Frank L's Avatar
I agree do you have a different gallon of fuel to try?
Old 06-23-2010, 10:15 PM   #7
vti-chris's Avatar
We tried 45% RB fuel the same day on one of the engines and we still had the same problem.
I'll see what i can do!!
Thanks for the replies!
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 06-23-2010, 10:18 PM   #8
houston's Avatar
ya baby !! 45% , you better adjust your shimming
Old 06-24-2010, 07:41 AM   #9
pickle311's Avatar
Trader Rating: 31 (100%+)
they seriously make 45% nitro now? Dang, I thought people were crazy when I first got back in the hobby and saw them running 30%.
pickle311 is offline   Reply With Quote
Old 06-25-2010, 03:27 PM   #10
Is it three seperate engines in three different cars? Or three different engines in the same car? Maybe the airfilter was used on all three and it leaks dirt by. Need to think of what may be common between all three engines.
Dirtdobber is offline   Reply With Quote
Old 06-25-2010, 03:36 PM   #11
cdc
try new fuel
Kyosho MP9 TKI4 - OS SPEED - KO RSx Servos - Futaba 4PX
cdc is offline   Reply With Quote
Old 06-25-2010, 03:59 PM   #12
Does a air leak usually make your engine run lean? i am asking because i have been having the same problem (sort of). Both my motors run fine at wot and mid but for some reason they won't idle at all really. It will cut out in about 5 seconds once the idle drops. It is a serious bog that sounds like it should be spitting fuel out the tail pipe like a fire hose. Have changed P/S/R, bearings, fule tanks, even the thermal sleeve. It's not the linkage, don't know what it is. I will say it's times like this that make me rreeaaalllyyyy want to go electric or just quit.
Got off topic, so if my engine is boging down like it is too rich, would an air leak cause that? Doesn't a air leak cause the idle to be erratic and go up and run hot temps? Just trying to eliminate the air leak theory. I have leaned it wwaaayyy out as well and that does not help at all. Got a little better when i turned the midrange screw a half turn in, but the power band was crap and ran like poo. Not the glo plug. Maybe it's my cheap glo ignitor. Although i have changed batteries often.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-25-2010, 05:05 PM   #13
triplebvalp's Avatar
Glow ignitor won't have a thing to do with they way the engine idles. Don't you have another thread on this same topic?
Anyway, as suggested in the other thread, lean her out some more ... high summer temps with high humidity = a rich engine. I had to lean both my Truggy and Buggy quite a bit with the temps soaring they way they are.
triplebvalp is offline   Reply With Quote
Old 06-25-2010, 10:11 PM   #14
vti-chris's Avatar
Engines are on different cars.
On one car we found that the lid that closes the tank was weak and at WOT and high pressure it poped the lid open a bit.
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 06-26-2010, 01:16 AM   #15
modified763's Avatar
Trader Rating: 73 (97%+)
Try running a super hot glow plug. I had the same problem and found that I was running too cold of a plug. OS or O'Donnell plugs are the best in my opinion.
Possibly a broken clutch spring or hung clutch shoe? Also check your clutch bearings. One could be seized. Try Boca clutch bearings. They are pretty efficient.
Team Hot Bodies, Team O.S.Engines and Glow Plugs, Team AKA Products,Team Boca Bearings, Team O'Donnell Speed Blend Fuel, Team Upgrade RC, Tesla, Billy Oceans
modified763 is offline   Reply With Quote
Need HELP with V-Spec Mo-Bo0st Nitro Off-Road 9 07-12-2008 08:47 AM
Team magic G4 RTR (Need help with factory engine settings) BIGTACO Nitro On-Road 10 11-15-2006 09:30 AM
Need help please with Sirio XER987 Nitro On-Road 9 03-25-2003 03:46 PM
