Old 06-23-2010, 06:37 PM   #1
Default Buggy distroyed .. run away
I had an Ofna Buggy I was trying to tune ... about 1 gallon ... I started it up ran it a bit in the lot to get the engine up to temp.. and i was going to go down and run it on a semi natures track if you will ... ( empty retention pond) .. I ran for about 30 seconds .. then gave it some gas got it about 30 feet away ... hit the brake to turn it around .. then all of a sudden its gunned full throttle.. i had no control ... it hit a curb hitting it head on ... buggy came to a stop but then engine wound up so bad .... I was running .. but i couldn't make ... POP there goes my engine...thing bent in half breaking everything in its way ... front end and rear seem fine .. try is bent and everything else.. Engine threw the rod broke the piston and messed up the sleeve... What could have caused this?? I have a good radio ... Futaba 2.4 3pm.. this was my first and only buggy and im heart broken..
TCaputo - Losi 8ight 2.0, Losi 350 Turbo, RE-11
Tcaputo is offline   Reply With Quote
Old 06-23-2010, 06:40 PM   #2
also my flywheel has a bit of a gouge in it ... will that cause troubles .. or is that just cosmetic and not need to be replaced?
Old 06-23-2010, 06:46 PM   #3
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
i bet the receiver overheated. futaba 3pm 2.4ghz receivers are known for this had it happen to me twice last race season. i put heat reflective tape on radio box between my motor so it reflects alot of the heat never had a problem since.
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 06-23-2010, 06:49 PM   #4
guss2009's Avatar
Trader Rating: 265 (100%+)
Wow. Maybe your battery went dead.
Losi 8ight 3.0 / Losi 8ight 2.0T / CRE Werks B6 Pro / CRE P5XL / Nova 4BTT
/ Dx4r Pro / Hitec 7955tg / Nova/Werks Pipes/ Werks Pro Clutch / Werks Fuel
/ GunHill Road Track (Ft Knox Park) / NYPD
guss2009 is offline   Reply With Quote
Old 06-23-2010, 06:49 PM   #5
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
no always true but sounds more like you forgot to charge the reciever pack or the switch took a dump.... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 06-23-2010, 06:50 PM   #6
jbright33's Avatar
also dont put any stuffing of anykind in the radio tray it will overheat faster futaba actually tells you not to use any. and just for sake it ever happens again go to walmart and buy some hair bands for 97 cents and put like 3 around your carb so if it looses signal it will go to idle.
JESSE BRIGHT
Old 06-23-2010, 06:51 PM   #7
or ur battery went dead and u didnt set ur fail safe, or u throttle servo went bad, bad switch, could be anyting, over heating during break in i find that hard to believe
skidoos is offline   Reply With Quote
Old 06-23-2010, 06:56 PM   #8
jbright33's Avatar
could be the switch or he forgot to charge the pack. but 3pms have a fail safe on them. and if its a new car i wouldnt think it was the switch but never know. im just looking at all the people i know that had problems with those receivers me includded.did any of the electronics work after the crash?? if it didnt work when you picked it up and it works now its most likely a receiver overheating. if nothing works then it was somethin else.
JESSE BRIGHT
Old 06-23-2010, 06:59 PM   #9
jbright33's Avatar
im not putting futaba down cause i run futaba but i had one overheat from setting and warming up before race then i went out to warm up and it overheated..
JESSE BRIGHT
Old 06-23-2010, 07:00 PM   #10
mugenize1's Avatar
I put this on my Truggy and Buggy
Nitro Rc Car 1/8 THROTTLE RETURN SPRING - 44MM
mugenize1 is offline   Reply With Quote
Old 06-23-2010, 07:08 PM   #11
captain america's Avatar
Throttle return springs/rubber bands are only to bring your throttle back to idle if the ball cup disconnects: even with no power, the servo produces so much friction that any spring/band with sufficient tension to bring the carb back to idle with the servo still attached will damage your servo.
captain america is offline   Reply With Quote
Old 06-23-2010, 07:10 PM   #12
mugenize1's Avatar
I would like to break a servo then my cars man
Old 06-23-2010, 07:11 PM   #13
Its was already broken in ... I was only running for a few minutes today ... so doubt overheating .. After i got home with it .. i turn on the radio just for shits to see what was up ... everything moved fine after .. Ive run about 20 min on this charge .. 5 cell hump pack
Old 06-23-2010, 07:13 PM   #14
mugenize1's Avatar
Maybe the bind was not done correct for the fail safe.
Old 06-23-2010, 07:17 PM   #15
RUNNINONMT's Avatar
HUH my digital servos take hardly any force to move when there is no power to them. with no rubber band and the linkage off the boot on my carb moves my servo and hold the carb open.
RUNNINONMT is offline   Reply With Quote
