Old 06-24-2010, 10:09 AM   #46
scoopdaloop's Avatar
Trader Rating: 10 (92%+)
Send a message via AIM to scoopdaloop
Default Futaba sucks
Same here, I have a 3PK that will endure the rest of its life on the SHELF. I continually get the thermal shut down with the RX. While I run bands on the carb, I would get temporary 1-2 second glitches where I would lose all control. Called Futaba and they could have cared less. They said they had never heard of that problem, bahah whatever Futaba.
Just ordered the M11..
Only other thing you can do to avoid the overheating, is to move your RX to the front battery slot and move your battery to the rear RX slot. Then I put a 2 grams of lead weight on the front to compensate for the weight x-fer.
Tekno SCT410/OrionR10 Pro + Novak 4.5 Ballistic/Hitec 7955tg
AE B4.2/Tekin RS Pro/D3.5
I'm a tech nerd, watch out son.
scoopdaloop is offline   Reply With Quote
Old 06-24-2010, 10:12 AM   #47
I have a futaba 3pm for sale .. lol .. man this sucks so bad ... this is a expensive lesson..
TCaputo - Losi 8ight 2.0, Losi 350 Turbo, RE-11
Tcaputo is offline   Reply With Quote
Old 06-24-2010, 10:52 AM   #48
sucks for yall. I have the same m11 i got when i started nitro. Did not even hear or know what a thermal shutdown was until i read this thread lol
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-24-2010, 11:07 AM   #49
laugh on funny guy ..
Old 06-24-2010, 11:28 AM   #50
iznasty's Avatar
I have a 3pm also, never knew they had overheating problems though, guess it's time for an upgrade.
Mugen MBX-6 w/ Alpha Z852
iznasty is offline   Reply With Quote
Old 06-24-2010, 01:38 PM   #51
RUNNINONMT's Avatar
I run a 3pk with spektrum 2.4 i wrap my recievers in tire foam and haven't had a problem in over 3 years.
RUNNINONMT is offline   Reply With Quote
Old 06-24-2010, 03:56 PM   #52
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
The fail safe will only protect if you radio goes dead or if your out of range. If your receiver battery has an issue and if it get stuck in open throttle good luck . A rubber band or a spring attached to your carb will protect your kit if you loose a battery. It will add extra tention but buying a (Hitec) will solve that issue.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 06-24-2010, 04:14 PM   #53
Originally Posted by Tcaputo View Post
ok so now i need a new buggy .. i priced it out .. not gonna be worth fixing .. So what should i get now ... lol oh also i have a "slightly used" Ofna for sale ..
Which Ofna is it?
If its an Lx comp I would like to know the condition of the front shock tower.
K-Train is offline   Reply With Quote
Old 06-24-2010, 04:26 PM   #54
benamin's Avatar
Originally Posted by RUNNINONMT View Post
HUH my digital servos take hardly any force to move when there is no power to them. with no rubber band and the linkage off the boot on my carb moves my servo and hold the carb open.
I agree, I have the 3pm and have the failsafe set. But because of heating issues I've heard about ( never happened to me) I use elastic bands for return. Running the futaba 9350 on throttle, the bands return the servo nicely!
And yes I tested it.
Mugen MBX-6T/Clockworks Novarossi Keep Off 21-7 XL, Clockworks Werks B5/2013
President,RC Racers of Edmonton
benamin is offline   Reply With Quote
Old 06-24-2010, 04:50 PM   #55
losi_racer's Avatar
Trader Rating: 25 (100%+)
do not put a return spring on a car, use little hair ties http://www.walmart.com/ip/Goody-Ouch...50-ct/10320307
if you use a spring you will start eating into your air filter and your carb boot.
and the discussion about futaba, i really like the feel of those radios but ive heard to many stories about those receivers going bad and destroying engines. ill stick with my 3r
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-24-2010, 04:59 PM   #56
Originally Posted by 2fst2c View Post
+1 except I went to the M11X after fighting thermal shutdown. I did however have my failsafe set so I wouldn't have a run away.
please dont rub it in ... lesson learned .. i really thought it was set .. but cant do anything about it now ...
PS I am starting a curbs suck fund .. anyone wanna donate .. pm me
Old 06-24-2010, 07:55 PM   #57
bigjayjay1's Avatar
Originally Posted by losi_racer View Post
actually failsafe needs power to work. Only thing a failsafe does is if your radio dies or your out of range. your receiver still needs power for a failsafe to work. and do not put a return spring on a car, use little hair ties http://www.walmart.com/ip/Goody-Ouch...50-ct/10320307
Thats what I stated right ? been running Futaba and Im in hawaii not issues here
Old 06-24-2010, 07:58 PM   #58
losi_racer's Avatar
i re read it, i swear i read it differently, sorry i corrected it
and i didnt say ALL futabas are having issues, but ive heard and seen my fair share, enough to keep me away
Old 06-24-2010, 08:03 PM   #59
Originally Posted by K-Train View Post
Which Ofna is it?
Its a Picco ... and just fyi the front section is fine .. so is the rear .. shocks are good also ... but not sure any would fix lx ??
Old 06-25-2010, 08:46 PM   #60
Integra's Avatar
Originally Posted by mugen8605 View Post
FASST receivers and nitro buggys don't mix.
100% False.
