Old 06-23-2010, 07:17 PM   #16
iznasty's Avatar
Originally Posted by mugenize1 View Post
I put this on my Truggy and Buggy
Nitro Rc Car 1/8 THROTTLE RETURN SPRING - 44MM
I tried using hair bands like some people suggest but I must have 1 strong servo because I have like 10 of those suckers on their and my servo doesn't budge(with no power), I guess it would help if the linkage popped somehow but that's about it.
Mugen MBX-6 w/ Alpha Z852
iznasty is offline   Reply With Quote
Old 06-23-2010, 07:17 PM   #17
Maybe the bind was not done correct for the fail safe.
I dont know .. This really sucks bad ...
TCaputo - Losi 8ight 2.0, Losi 350 Turbo, RE-11
Tcaputo is offline   Reply With Quote
Old 06-23-2010, 07:19 PM   #18
RUNNINONMT's Avatar
Originally Posted by captain america View Post
Throttle return springs/rubber bands are only to bring your throttle back to idle if the ball cup disconnects: even with no power, the servo produces so much friction that any spring/band with sufficient tension to bring the carb back to idle with the servo still attached will damage your servo.
RUNNINONMT is offline   Reply With Quote
Old 06-23-2010, 07:20 PM   #19
mugenize1's Avatar
Originally Posted by RUNNINONMT View Post
HUH my digital servos take hardly any force to move when there is no power to them. with no rubber band and the linkage off the boot on my carb moves my servo and hold the carb open.
When a receiver jumps into fail safe it is using power it has to he has an 2.4G
mugenize1 is offline   Reply With Quote
Old 06-23-2010, 07:22 PM   #20
RUNNINONMT's Avatar
sorry it misquoted me i was responding to thew post about return springs damaging servos
Old 06-23-2010, 07:26 PM   #21
mugenize1's Avatar
Cool
Old 06-23-2010, 07:29 PM   #22
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
yea im not getting what he is saying only way im seeing it is that his throotle is pulling with the tension of the spring trying to pull it back. but were talking about loss of power to servo. i dont know what kind of servos he is running but i know my servos one band will bring it back but i always put 2 or 3 on incase one breaks from heat and with bands you dont have the tension on the servo like the spring. and these arnt the big colord bands there just little tiny rubber bands kinda like the ones for braces.
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 06-23-2010, 07:29 PM   #23
No cool ... This is a sad thread ..
Old 06-23-2010, 07:31 PM   #24
On the 3pm, if you are running in normal (non digital) mode for standard servos you must set the failsafe everytime you power up the remote. If you are running in HRS (for digital servos) mode you can "set it and forget it".
one8updragracer is offline   Reply With Quote
Old 06-23-2010, 07:32 PM   #25
I didn't have bands ... Not sure if it would have helped ... But you better bet if I can get another I will do that...
Old 06-23-2010, 07:36 PM   #26
well i didnt do that .. i was not running digital .. yet another lesson for the rookie
Old 06-23-2010, 07:38 PM   #27
ok so now i need a new buggy .. i priced it out .. not gonna be worth fixing .. So what should i get now ... lol oh also i have a "slightly used" Ofna for sale ..
Old 06-23-2010, 07:38 PM   #28
RUNNINONMT's Avatar
can we se some pics im all antsy and want see what i looks like now
Old 06-23-2010, 07:43 PM   #29
trx-1racer's Avatar
Thats just not true with todays good servos. I use a relatively light spring and with the throttle wide open I can turn the radio switch to off and it goes right back to idle position.
www.shortcoursehobbies.com
T-RCE Slash 4x4 - Kyosho SC-R - TLR 22
Think you're fast? Try racing in Arizona, it's like going to the Nats every weekend...
trx-1racer is offline   Reply With Quote
Old 06-23-2010, 07:49 PM   #30
We use hair bands. You only want enough to close the carb with the servo disconnected. Putting to many on it puts stress on the barrel of the carb and can cause binding. A TL team driver gave us the heads up.
Chris Reilly is offline   Reply With Quote
