Nitro tunning help...
Im new to nitro I have a picco .21 thats broken in already.. When its up to temp it idles but when i try to give it gas it bogs down .. Like the engine is loading up.. but after i get it cleared it runs mid - high revs pretty well with alittle smoke.. If i lean out the HSN it seems to lean bog on the high end .. should I lean out the LSN ?? .. do you think the HSN can be to lean if when i lean it a half or whole turn it lean bogs .. any help or tips would be great
if its lean bogging when you rev it high richen it up a little on top and lean your LSN to keep it from loading up.
Thank You very much when I will try to get it when i get home ..
