Old 06-22-2010, 01:42 PM   #1
Busterlbn's Avatar
Default Your method to rebuild MBX-6 shocks
Hello.
Could you tell me what is your method to rebuild shocks ? And does damper shaft always extends to end ? Because i'm rebuilding my shocks now and damper shaft don't extends to end.
Regards,
Dorian
Mugen Seiki | Novarossi | Futaba | AKA | Pro-Line | RB
Busterlbn is offline   Reply With Quote
Old 06-22-2010, 04:44 PM   #2
JASON671's Avatar
Trader Rating: 50 (98%+)
Originally Posted by Busterlbn View Post
Hello.
Regards,
Dorian
thats ok, you never want them to rebound all the way out. a good starting point is build them to rebound half way out, make sure both shocks rebound the same length. when you bleed them you wan to unscrew your cap about one turn, push the shock shaft up to about three quaters to fully compressed then while holding the shock shaft at that length tighten the cap. then check your rebound by pushing the shock all the way in then see how far it comes out and repeat if necessary till you get the rebound you are looking for. make sure both are the same. i like 25% rebound. hope this helps, im sure others will explain it better, i am no expert and i am still learning but that is how i was told to build mugen shocks and it works great.
JASON671 is offline   Reply With Quote
Old 06-23-2010, 10:12 AM   #3
Busterlbn's Avatar
Thank you for answer. I tried that method with unscrew caps and it works! Once again thanks.
Regards,
Dorian
