Old 06-23-2010, 07:35 AM   #16
JSR
Trader Rating: 18 (100%+)
Thanks for all the great suggestions guys.
I don't think I have the time for the x-acto cut method. I'm lucky to have 15 minutes where I don't have to take care my son, so I don't have time to sit with a blade to carefully cut it out. That's how I work on my cars too...15min here...take care of baby...10min there...take care of baby...2min to almost start to work on car...take care of baby...carryover to next day and so on...haha.
I'll try to see which method would be best for me. Thanks again for all the options.
JSR is offline   Reply With Quote
Old 06-23-2010, 08:51 AM   #17
Lonestar's Avatar
I'm struggling to understand how a tire that's been left either in heat (300F sounds hot to me, boiling water is decently hot too I would think) or in chemicals will have the same physical/chemical properties (read: generate the same grip/life expectancy/...) as one that's never been tortured that way... do they perform the same afterwards
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-23-2010, 10:58 AM   #18
Joe_Racer's Avatar
Trader Rating: 31 (100%+)
Check this out for the exacto method.
+ YouTube Video
Jack G.
Mugen MBX-7 Novarossi Plus 4, Mugen MBX-6TR Novarossi P5
RC10 GT2 OS TG, RC10 B4.2 17.5, SC10 FT 13.5, RC10 T4.1 13.5
Joe_Racer is offline   Reply With Quote
Old 06-23-2010, 01:27 PM   #19
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by DANE_TRAIN View Post
acetone is a good last resort. It will change the compound of the tire, and most likely ruin the insert.
What I do is wash the tire, then sit on the couch and watch tv while I use a sharp x-acto knife to slowly cut the tire from the rim. You can them reuse which ever part you need.
This is probably better since you plan to reuse the tires. I am normally only interested in the wheels.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 06-23-2010, 07:51 PM   #20
Did you call Panther about the wheel issue? The new Panther large wheels are perfect, I haven't had an issue with them. Call them and let them know what happened. If the wheels are defective you may be able to get some help.
Btw, I have a 5 gallon Home Depot bucket and lid that I put like 2.5 gallons of acetone in then I take the tires (with gloves on) submerge the tires in the acetone. I squeeze the tires to fill the inside of the tire and foam to let it sink to the bottom of the bucket. By the next day I just pop off the tires off the wheels like they were never glued in the first place. I have seen Astushi Hara do the xacto knife method. That way looks pretty easy. If I have to remove tires again I will try that way.
Tekno Rc~Dialed-Rc~James Racing Tires~Tekin~DE Racing
Mark K is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
LOSI XXX-S, Tips and Tricks, Open Mod, etc John Stranahan Electric On-Road 1044 03-08-2017 04:30 PM
FAQ's for VTA wiscnitro Electric On-Road 27 09-17-2009 05:55 PM
Removing good tires Smoke21 Rookie Zone 11 10-31-2003 05:45 PM
