Old 06-21-2010, 04:16 PM   #1
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Unhappy GRP CARB HELP
well i got 2 questions for you guys 1 is i seem to have lost my carb uniball joint so if you guys can tell me which one will work with the grp tunned version it will help me alot and save me $$$ so first which will work? i know ninja is basically grp and they are the only carriers that seperate there carbs that will help
http://www.amainhobbies.com/product_...-Uniball-Joint
http://www.amainhobbies.com/product_...niball-Joint-1
they look diffrent but are both ninja uniball joints so im not sure which it is also i found this but will just the uniball joint off i work on my tunned versio it is a grp .21 buggy carb
http://www.amainhobbies.com/product_...retor-21-Buggy
thanks for the help i also am ganna rebreak in my grp it was ran on byrons 20 but i want to run byrons 30 so what would be the best recremended way to move up in fuels im not changing brand just going up in %???? i was concidering full rebreak in but i heard u dont need to in just going up with same brand as fuel so i was thinking just get it rich and letting it idle 2 or 3 tanks at 200 degrees
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 06-21-2010, 04:23 PM   #2
jyfz2's Avatar
You want the second one. the grp is based of the mr ninja. the first one is for the jx ninja it is os based.
jyfz2 is offline   Reply With Quote
Old 06-21-2010, 05:27 PM   #3
jmaxey51's Avatar
the new TQ racing engine is GRP done over. i was told all parts off it will work just fine in a GRP. i mean look at the engine, tell me if you see anything different: http://www.amainhobbies.com/product_...ine-Turbo-Plug
also are these any of the parts you need? http://www.amainhobbies.com/index.ph...ts-Losi-GRP-21
jmaxey51 is offline   Reply With Quote
Old 06-21-2010, 06:18 PM   #4
mugenize1's Avatar
+3 that is true the GRP and the TQracing are the same even Better!!!!!!!!!! Go to TQRACING.COM
mugenize1 is offline   Reply With Quote
Old 06-21-2010, 06:47 PM   #5
plus2ss's Avatar
For 25 bucks you could get an entire GRP carb from amain. Its the one that came with the sport engine, but the part you need is there, plus extras! Ive got a sport silver head GRP that still gets 12min per tank and runs awesome. Cant wait to see those TQ/GRP's in action!
plus2ss is offline   Reply With Quote
Old 06-21-2010, 06:51 PM   #6
plus2ss's Avatar
Oh and if your switching from 20% to 30%, i would heat cycle it for a few tanks and then run it. 30% will run a bit cooler than the 20%.
Old 06-21-2010, 10:20 PM   #7
thanks for all the help guys yea plus i normally run 30% but the grp has been laying around for a while when i ran 20 so i put it back to factory settings today and once i get the uniball joint im ganna heat cycle it and run it fat for a few tanks
Old 06-21-2010, 10:21 PM   #8
thanks alot for ur help
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
GRP ENGINE HELP losi_racer Nitro Off-Road 24 03-19-2009 01:47 PM
grp motor help mixedguy Nitro Off-Road 20 06-24-2008 01:53 AM
