Old 06-21-2010, 01:04 PM   #1
Trader Rating: 74 (100%+)
Default Are the bearings toast or is it something else?
All four wheels on my Losi 8ightB 2.0 have excessive slop. With the wheels on the car you can wobble them quite a bit. If you take the wheels off, its a little more difficult to notice the slop/wobble, but its certainly there. I have the aluminum spindles, carriers and rear uprights on this buggy and the entire buggy has about 3 gallons on it.
I'm just not sure I can pinpoint what is causing the slop. I took the front spindles and carriers off and slid the cvd through the bearings in the spindles. It doesn't feel like there is any slop in the bearings. Put the entire assembly back together and its just sloppy. If I were to guess at this point, I'd say it feels like the aluminum upgrades have slop at the mounting pins and bolts. I never noticed it when I first installed the parts, but maybe there were like that from the beginning?
Does 3 gallons sound about right for cvd/wheel bearings to wear out? Do the aluminum spindles, carriers and uprights just have more slop than plastic, or did the aluminum parts cause the mounting pins and bolts to wear out quicker?
I have a whole new set of cvd/wheel bearings on order, but if that doesn't eliminate the slop I'm at a loss.
Thanks in advance for any insight!
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 06-21-2010, 01:06 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Come on Matt, It's a losi. It's supposed to be that way. Anyway, I should be at McCullough's this weekend, so I can take a look at it for you if you like. If anything I bet you just need a new set of bearings. I change mine every couple gallons or when they get gritty.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-21-2010, 01:13 PM   #3
I know Koby, that's why I think the Losi is going to become an e-scale at the end of this season, and there will be a new Mugen MBX6 in the stable for the start of next year's outdoor Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Old 06-21-2010, 01:18 PM   #4
Trader Rating: 14 (100%+)
It is probably the aluminum wheel hexes. Since it has only 1 pin holding it in place, when the axle and hex wear together, the hex rocks back and forth on the pin. You can drill and tap a 2 mm hole for a set screw on 2 of the flat spots on the hex and this will take out alot of the slop.
mwiley is offline   Reply With Quote
Old 06-21-2010, 01:38 PM   #5
Trust me, you don't want it to be tight. Try tightening the losi up and see how it drives. I guarantee you will be putting it back to how it was. Anyway, a lot of the slop in them comes from the wheel hexes. The pin holes wear out, and create a bit of wobble. If you really feel the need to get rid of that, just replace the hubs and pins. 3 gallons on the bearings is quite a bit. It may be time for a new set. At $1 a piece, it is worth it to change them often.
-Koby Kubrin-
Old 06-21-2010, 03:26 PM   #6
Zerodefect's Avatar
Usually it's the rod ends and the bearings then the hex and pin later.
Zerodefect is offline   Reply With Quote
Old 06-21-2010, 03:28 PM   #7
Pull it apart and check it.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-21-2010, 06:55 PM   #8
lowcountrytj's Avatar
Most of the wear or play that I am used to seeing in my Losi cars ended up being in the rod ends,steering rod ends,and carrier pivot points at the arms...I usually check the bearings after about every other race.Or if they are rough or gritty like someone else said.
LOSI 8B--8T///SC10--Im not on a budget,I have a fudget
Team Terribles
Phil Hurd Raceway S.C.O.R.E. Savannah Ga(2nd Oldest RC track in the US)
lowcountrytj is offline   Reply With Quote
Old 06-21-2010, 07:04 PM   #9
Team Terribles
Old 06-21-2010, 07:28 PM   #10
jammin32j's Avatar
From my experiences most cars drive better when they get a little slop/play in them.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 06-21-2010, 10:04 PM   #11
TheFcuddy's Avatar
You think your buggy is sloppy? Go check on a truggy and you will think your ship is tight! I check bearings after every weekend. I pray to god I don't have to replace them but I still like to know the status. My RC cars are maintained better than my car! Is that scary or what?
Sweep Racing Tires www.sweepracingusa.com
Team Tekin www.teamtekin.com
PowerHouse RC Performance www.powerhousercperformance.com
First Turn Racing www.FirstTurnRacing.com
TheFcuddy is offline   Reply With Quote
Old 06-21-2010, 11:06 PM   #12
same here
mx1nitro is offline   Reply With Quote
Old 06-22-2010, 07:34 AM   #13
Frank L's Avatar
Trader Rating: 148 (100%+)
Check the rod ends to make sure it's not there then I ended up trying the x-Ray hexes. They bolt right up and so far they are much tighter than the losi stuff. That is the easiest fix and there's no modding required. You just gotta spend a couple $$
Old 06-22-2010, 08:21 AM   #14
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
That's a good start... now you just need to upgrade the rest of the parts to XRAY stuff!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-22-2010, 11:29 AM   #15
Trader Rating: 96 (100%+)
The aluminum wheel hexes have some play in them from the factory, and it gets worse as time goes on. As one other person mentioned, drill and tap the hex and install some set screws to keep the hub from wobbling side/side. I've used shim stock ( .001-.002 thickness ) wrapped around the cvd, then slide the hub over that.
K.Copeland is offline   Reply With Quote
