Mugen MBX5 & MBX5-T question
I have purchased a used Mugen MBX5T from a RCTech.net member which will be arriving this week and have a question.
I've been shopping around for an electric conversion kit for this vehicle and inquired with Novak about the suggested Motor/ESC to use. They replied back that they carry a full conversion kit for the vehicle. Here is the link. The description says its for an MBX5, not an MBX5T. So I want to know for sure if this will fit. I'm not very knowledgeable when it comes to Mugen and I don't know if there are too many difference between the buggy and truggy that would make this kit work or not. Any help would be appreciated, thanks! |
i would of thought it would of fitted because mugen, losi, hot bodies buggies and truggies have the same layout and the only difference is length of suspension arms, shocks chassis length.
basically the bits the middle are the same and the four corners are different from buggy to truggy hope this helps lewis |
It will fit with no issues.
Thank you both for your replies :)
