Help with dying buggy when it lands
#16
cool
i sent u a PM about breaking in your engine.
#17
I wouldn't touch the bottom end just yet. If it idles down eventually, then the low-speed needle is pretty close to where it needs to be. If it's staying at high idle after releasing the throttle, it's a strong indication that it's very lean on the high speed needle. Open up the main needle until the engine idles down properly - the bottom end will get a little richer by opening the main needle anyway.
Sorry, didnt mean "turns" on the bottom end. I meant 1/4 to a 1/2 hour out. 1/4 to 1/2 turn out? Whoa!! Totally my bad, but the top end for sure sounds like its lean.
