Old 06-19-2010, 11:38 PM   #1
hdcruzer's Avatar
Default Losi 8t 2.0 rear diff.
What is the best way to shim the diff on these things. I tired of blowing rearends. I shim em tight and they blow, I shim them with a little bit of play they blow. Also how often should the cases be changed out? Thanks.......
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 06-20-2010, 01:21 AM   #2
modified763's Avatar
Trader Rating: 73 (97%+)
How old is your chassis? If it gets bent or wears out in the rear of the chassis, you'll start to blow diffs for sure.
Team Hot Bodies, Team O.S.Engines and Glow Plugs, Team AKA Products,Team Boca Bearings, Team O'Donnell Speed Blend Fuel, Team Upgrade RC, Tesla, Billy Oceans
modified763 is offline   Reply With Quote
Old 06-20-2010, 01:57 AM   #3
off road god's Avatar
Hmm...I ve just started having this problem..2 times in the last 2 mo. At the same hi bite clay track. I don't like it.....
WERKS RACING...PRO1RC...HEX CREW...BATTLEFIELD R/C...LOSI 2.0...JP PIPES...AKA,PROLINE TIRES...SPEKTRUM DX3R...JR SERVOS... PAUL CONWAY,TECHNICAL ADVISOR.
SAKURA ZERO S...NOVAK ELECTRONICS...MI SERVO...HPI PRODUCTS...FUTABA
off road god is offline   Reply With Quote
Old 06-20-2010, 07:52 AM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
are you replacing the gear box case when you are replacing the gears?
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-20-2010, 08:52 AM   #5
hdcruzer's Avatar
No I havnt been changing the case. I change the diff holders. I just found out though that because of the heat inside the diff it is also wise to change the case also.
Coldfusion Fuel
Henchman Racing
Old 06-20-2010, 03:54 PM   #6
Trader Rating: 20 (100%+)
In the last week iv had to put in 2 ring gears and a 1 pinion so I'm starting to have this issue. I'm just going to get a new diff case holder. I also put the alu diff things that go on the diff cups in so I think that will solve all problems.
Matt Piva is offline   Reply With Quote
Old 06-20-2010, 04:01 PM   #7
losi_racer's Avatar
when you change ring or pinion change them both. when new they wear together, you put a new and used together you will prob strip another one. always do that and change the gear box case. ive lucky never blown a r/p since owning the 8t 2.0 , i got it right when it came out
Old 06-20-2010, 04:08 PM   #8
I've never blown one. I have it shimmed with a very small amount of play. I bought several sets of diff cases and gears expecting it to happen, but it hasn't.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 06-20-2010, 04:47 PM   #9
X2
Old 06-21-2010, 09:09 AM   #10
I just had the rear diff gears blow this weekend, what are the aluminum spacers??could ou post a part#.I just bought my trug second hand, and want to fix this issue correctly. any help is appreciated
moa losi comp crawler/blitz ese/mdrccrawlers.com/full throttle raceway/pornhub/
rock addict is offline   Reply With Quote
Old 06-21-2010, 09:20 AM   #11
All you need is the alum rear bearing holders, The plastic ones wear down causing the gear mesh to move apart... Get the alum one and shim per instructions and you should have a problem.
LOSA4454
http://www.losi.com/Products/Feature...rodId=LOSA4454
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-21-2010, 09:58 AM   #12
LOSA4454
thanks man
Old 06-21-2010, 10:18 AM   #13
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Also... if you replace the ring and pinion due to it being "blown..." replace the bulkhead. It probably got warped when the ring and pinion got damaged.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-21-2010, 10:29 AM   #14
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 you have to change the case too.
LOSA4454
+1 on the alum holders. I have had gears get noisy and when they get too noisy then I replace them but I reuse the alum insert.
The only other thing that will blow rear diffs in this truck quickly is when you land off a jump dont be on the gas hard. Let the truck land and then hit the gas. I have seen more guys blow new r/p because they were on the gas too much.
Old 06-21-2010, 10:32 AM   #15
Arco's Avatar
Spot on!
OverdriveRC.com
"Promote and Support"
Arco is offline   Reply With Quote
Losi 8T 2.0 roller with Headz hopups luckypunk R/C Items: For Sale/Trade 9 06-04-2010 04:02 PM
Losi 8B 2.0 & Losi 8T 2.0-1 gallon on each TKirk R/C Items: For Sale/Trade 35 03-01-2010 05:36 AM
New Season New Truggy: Mugen Mbx6t or Losi 8t 2.0 larso10 Nitro Off-Road 34 01-16-2010 06:06 PM
Losi 8T 2.0 LOADED WITH UGRADES!!!!! Jonathan Bell R/C Items: For Sale/Trade 15 05-06-2009 01:58 PM
