Old 06-19-2010, 08:47 PM   #1
Trader Rating: 32 (100%+)
Default hitec servo issue HS-7954SH
I am having an issue with my servo where the throttle returns or responds slow All transmitter adjustments are linear. There is no binding actually the servo is pretty new. I looked at Hitecs FAQ and it says use a receiver switch with 22awg wire. Has anyone had this issue before. I know its not the carb, i put in a 5965 servo and it works fine. There are no tears in wire.
mcion is offline   Reply With Quote
Old 06-19-2010, 08:51 PM   #2
Zerodefect's Avatar
r u running a Losi?
Zerodefect is offline   Reply With Quote
Old 06-19-2010, 09:09 PM   #3
no rc8b with a reedy
Old 06-20-2010, 03:27 AM   #4
jsp619666's Avatar
Sounds like the servo motor went out, or maybe a the lead wire was cold soldered just send it back to Hi-Tec the customer service is second to none. I know its a hassle but better then blowing up a motor on race day. IMO never chance your throttle servo. Just my 2 cents.
Josh Peters
jsp619666 is offline   Reply With Quote
Old 06-20-2010, 06:31 AM   #5
Zerodefect's Avatar
Check your chassis braces. Replace thier ends. Maybe use spacers/washers to get the servo up higher off the chassis. Make sure that the bottom of your servo shows no wear marks. We don't want the chassis hitting the servo.
Make sure your using the rubber grommets and that your servo is not bolted down too tight. When you apply full brake the servo should actually swing a little because it's mounted soft on those rubber grommets.
And send it back to Hitech before it blows your engine.
Old 06-20-2010, 08:25 AM   #6
If I mount another hitec servo i have in the same spot, it does not have this issue though and it does it even if i am not driving the car, just gunning it on the starter box.
