Old 06-19-2010, 07:53 PM   #1
Default quick help???
I just got my new engine in the mail today... precirotate pr21c...
The carb is twisted at almost a 45 degree angle... i need to straighten it out... i took out the screw that loosens the carb so i could turn it where i needed it... but that carb still will not turn...and wont pull out... any ideas? i am using really solid force right now... more then what i think is necessary with the screw out... is there a trick to this? am I missing something?
deucedeuce is offline   Reply With Quote
Old 06-19-2010, 08:03 PM   #2
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
try hitting it with a heat gun or blow dryer heat loosens things up i could be wrong on using heat to remove carb but i use heat to remove sleaves and enginge bearings
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 06-19-2010, 08:04 PM   #3
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
ok here is what i would do... loosen the carb bolt by 3-5 turns... use the allen driver to push straight in on the screw for the carb bolt causing the black insert to be pushed out... loosen the screw all the way and remove both screw and black insert... then take the allen driver from the side that was just removed and push the other black insert out the other way... then nothing should be holding the carb in.. at this point you should be able to rotate/remove carb to get the correct angle.... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 06-19-2010, 08:06 PM   #4
lol.. yea i didnt think to try that yet.. all my other engines I just loosen the screw and spin the carb... i will try that now... has anyone else ever ran into this?
Old 06-19-2010, 08:08 PM   #5
true didnt think of that if the screw is out the other two pieces are not that pinch the carb in place.
is it just ur screw out or there should be total 3 pieces if its completly removed and u should be able to c thru the hole
Old 06-19-2010, 08:12 PM   #6
good news... carb turned...
bad news... where the insert flew when it popped is still unknown... lol...
it was jammed in extremely tight...
thanks for the help...
Old 06-19-2010, 08:21 PM   #7
glad you got it figured out . BTW how bout letting us know how the engine is when you get it running . I'm looking for a club race engine & was thinking of one of those . Thanks in advance
romax is offline   Reply With Quote
Quick Help Needed! MMM CBHVR6 Electric Off-Road 17 09-24-2009 06:47 AM
darn it agian i need quick help t-maxxfantom Onroad Nitro Engine Zone 12 01-10-2005 08:04 PM
