Old 06-17-2010, 08:40 PM   #1
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Default help with prolonging throttle servo in losi 8
ok first off i have used high dollar to chepo servos in my losi 8 1.0 buggy i have the tft chassie and am going thru throttle servos. any tips or tricks u have done would be helpfull. i was told it was from the chassie flexing and breaking the circut board. and that the heat kills them but 6 in a month dnt u think thats crap
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 06-17-2010, 08:46 PM   #2
Trader Rating: 12 (93%+)
Do you have the end points set right?
rcdude236 is offline   Reply With Quote
Old 06-17-2010, 08:47 PM   #3
neobart's Avatar
First make sure the linkages are as straight a humanly possible, next make sure when you hold full throttle on the controller, the throttle barrel can still be pulled an extra 1-2mm. I also don't run the return spring on the linkages, in stead I run rubber bands on the carb. When braking the spring can put a lot of stress on the servo. Also make sure the brakes are adjusted right so the servo isn't working harder than it needs to.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 06-17-2010, 08:54 PM   #4
Are you running the rear screw in the radio tray loose? The one under the RX and battery compartment does not need to be hard mounted, put two small o-rings over the screw before mounting the tray and snug the screw just to where the screw is not sticking out of the chassis. That will let the rear of the box float rather than create the twisting stress at the servo.
Wrencher is offline   Reply With Quote
Old 06-17-2010, 09:05 PM   #5
cool will try all these do u have a pic on how u have the ruberband setup
Old 06-17-2010, 09:36 PM   #6
Trader Rating: 119 (99%+)
i still dont understand how all of these people are burning up lipos like crazy in the losi buggies. i ran a 1.0 buggy for about 9 months and a 2.0 for another 14 months or so and i never went through one servo. maybe i was just one of the few lucky ones but i was running a jr 9100t on steering and an 8800s on throttle both of them on direct lipo and NEVER had one problem (knock on wood)
skoalisbad4me is offline   Reply With Quote
Old 06-17-2010, 09:37 PM   #7
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
http://www.losi.com/ProdInfo/Files/L...ke_Linkage.pdf
Make sure the servo isnt hitting the chassis guard I was having the same problem when I got the kit spent over 400 bucks on high end servos. Adjusting the linkages is key make sure your not over extending. Make sure your linkage isn't binding I sanded mine down a tad (Throttle).
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 06-18-2010, 03:39 AM   #8
lowcountrytj's Avatar
Yep,what they said...I ran out of the orings and started using a small piece of fuel tubing(same thickness of 2 orings) as my spacer and have since then.
I also use a strip of double sided tape on the bottom of the servo to give it a lil buffer if it takes a bad hit(reassurance) which happens on a regular basis with my driving...lol.
LOSI 8B--8T///SC10--Im not on a budget,I have a fudget
Team Terribles
Phil Hurd Raceway S.C.O.R.E. Savannah Ga(2nd Oldest RC track in the US)
lowcountrytj is offline   Reply With Quote
Old 06-18-2010, 03:50 AM   #9
neobart's Avatar
Here's a shot of the throttle bands.
P.S. I have seen I'm missing an c-clip from the brake cam.
Old 06-18-2010, 06:17 AM   #10
Frank L's Avatar
Trader Rating: 148 (100%+)
I must have went through 6 servos in a very short time before a team driver looked right at that exact spot and the servo was hitting he side chassis mud guard. I gave it a little dremel action and problem solved.
Old 06-18-2010, 10:58 AM   #11
bigjayjay1's Avatar
That was a hard lesson learned.
Old 06-18-2010, 11:10 AM   #12
Losi front brake is a little funny. I almost had it when i got my first car.
if you push, the front brake top linkage wire by hand, you can feel the front brakes rod travel till half way mark only and not beyond which other buggies in the market goes further than that.
All I did was limit my brake throw without using the dremel and have not broken anything yet.
king offroad is offline   Reply With Quote
Old 06-18-2010, 07:33 PM   #13
jeff_ellis_9's Avatar
neobart, where do you get those servo washers? The red ones under the screws? Link?
thanks
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 06-18-2010, 09:06 PM   #14
neobart's Avatar
Here ya go.
http://www.rcmodels.dk/product-639-1.php
Amain also have something similar if you search for "countersunk", but not red.
