Old 06-17-2010, 04:50 PM   #1
Trader Rating: 39 (98%+)
Default Asscoiated flywheels
Has anyone had problems with the flywheels, the posts come loose and move and end up rubbing against the clutch bell? 2 guys I know have now had this happen.
dayglo33 is offline   Reply With Quote
Old 06-17-2010, 07:10 PM   #2
Shane Racer's Avatar
There was a bad batch. Call ae and they will send you a new one.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 06-17-2010, 07:18 PM   #3
FLHX1550's Avatar
I had this issue with 2 different flywheels, AE wanted me to send them to them and they would "take a look at them"
I pressed them back in with a small press and no issues sense
FLHX1550 is offline   Reply With Quote
Old 06-17-2010, 07:59 PM   #4
How long ago was that, that they wanted you to send it to them? My friend called them and they had no problem sending him anew one. As for pressing it back in, we did a couple of times but once it heated up, then it started coming out. And 1 was very loose that could be pulled all the way off. My friends did get them about the same time so a bad batch could be. Thanks for the info.
Old 06-18-2010, 04:06 AM   #5
FLHX1550's Avatar
First one was in my RC8T-CE which I bought in March, the other came off of my RC8B which I bought in May, both from different places.
Old 06-18-2010, 07:04 AM   #6
Kalgard Racing's Avatar
I spoke w some AE Team guys and there is a problem. They claim even re-pressing and JB weld does not work. I had to use an old flywheel to get me thru the race. I would get a flywheel ONLY from AE, since LHS and Amain are probably on the latest production run where the probem is.
Kalgard Racing is offline   Reply With Quote
