Old 06-17-2010, 11:56 AM   #1
Default stalling out when the motor gets up to temp.
Is this symptomatic of loss of compression? It really does not idle that good but once it heats up over 200 degree and the idle drops it won't idle at all. Just cuts out. And it's not the tune.
Air leak is possible but i have tried everything. I am more and more convinced that the p/s need a pinch. I can push the piston just barely past tdc pretty easily. Just barely though.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-17-2010, 12:00 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
That's what it sounds like to me.. Check you compression when it dies/ won't idle.. I bet it is really easy to spin by hand..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 06-17-2010, 12:07 PM   #3
yeah, pretty easy. But then it's a vspec so if you have expierience with those motors you know how compression is with it. Having said that it is still easy to turn, even for a o.s. motor.
Mugen
Old 06-18-2010, 10:42 AM   #4
Trader Rating: 30 (100%+)
I dealt with this a little bit last weekend. It ended up being the fuel tank lid. Engine wanted to keep flaming out and not wanting to idle above about 220. I am assuming that as the temp rose, the pressure inside the gas tank was just enough to break the seal on the tank and flame out. Problem went away when I installed a new fuel tank. Another item to check.
Axial Wraith
sdtech58 is offline   Reply With Quote
Old 06-18-2010, 10:50 AM   #5
portyansky's Avatar
Trader Rating: 54 (100%+)
You need a pinch. Or a new p/s
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 06-18-2010, 10:52 AM   #6
hdcruzer's Avatar
Also could be a plugged pipe. Went through 3 different tanks,new pressure line, without fail at half a tank it would flame out everytime. Put a different pipe on and havnt had a problem since.
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 06-18-2010, 10:53 AM   #7
dreaux
not freaking you out.
do this. when you encounter this problems. change a new plug. and check the glow. beautiful. after a couple of heats, problems back again. mysterious flame out. check the plug again. dull flame.
if you experience this problem try changing to odonnell plug. it will go away. i have the same damn problem months ago and change up to 3 OS P3 plugs to finish a race.
looks like os have a bad batch of plugs some where out there. in the past the P3 plugs just run and run without issues.
king offroad is offline   Reply With Quote
Old 06-18-2010, 11:23 AM   #8
CKmaxx's Avatar
+1
Tekno NT48.3 and NB48.4 powered by OS Engines
Tekno ET48.3 powered by Tekin
CKmaxx is offline   Reply With Quote
Old 06-18-2010, 05:18 PM   #9
2fst2c's Avatar
Trader Rating: 114 (100%+)
Originally Posted by king offroad View Post
dreaux
Odd, I had the same issue last weekend with my +4. I'm running OD plugs. Changed lines and the plug. Ran great the next qualifier 7 mins. Took it out for the main and flame out after about 5 mins. Happened 2 more times after restarting. Pulled it out of the race and haven't messed with it since.
2fst2c is offline   Reply With Quote
Old 06-18-2010, 05:24 PM   #10
if it's running great, why change it?
Mugen
Old 06-18-2010, 06:50 PM   #11
2fst2c's Avatar
Think you miss read it or I miss typed it.. I had the flame out issue. Then I changed the plug and lines. Then I ran a 7 min qualifier with no problems. Didn't touch it and then in the main it flamed out 3 times.
Old 06-18-2010, 06:54 PM   #12
got it.
Mugen
Old 06-19-2010, 01:42 AM   #13
Bigedmond's Avatar
Trader Rating: 18 (100%+)
To be honest, it sounds like either a new P/S is needed or possibly a cracked block.
Bigedmond is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
