Old 06-17-2010, 09:04 AM   #1
Default Xray808 mainternance???
Anyone give me some tips for mainternance of my Xray808. When do we have to check up the Kit eg. front diff, bearings...?
I heard that we have to change the bearings of front and back diff. of running about 4 or 5 gallons.. thanks alot...
hancock is offline   Reply With Quote
Old 06-17-2010, 09:09 AM   #2
2fst2c's Avatar
Trader Rating: 114 (100%+)
All the information you'll ever need and more here..
New XRAY 808
2fst2c is offline   Reply With Quote
Old 06-17-2010, 09:19 AM   #3
I found the 808 to be high maintenance, but a joy to maintain.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 06-17-2010, 09:30 AM   #4
put it this way, there is no such thing as a low maintenance beauty queen...
the Achilles's heel of 808 is probably the pinion bearing assembly, which can be solved by regular maintenance and changing out worn bearings religiously, other than that it is virtually bomb proof...
F1 cars are hand rebuilt almost after every race...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 06-17-2010, 10:24 AM   #5
merdith6's Avatar
Default the 808
Easiest buggy to work on in my opinion. Changing the bearings is cheaper than some of the stuff in other cars. I've never had any issues with my 808. You heard right, change the pinion bearings every 5-7 races and you will be set.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 06-17-2010, 01:03 PM   #6
Zerodefect's Avatar
Default 809
2-3races: -pull front and rear diffs, check mesh
-Pull the pinion out and regrease the center CVD's
- regrease the pinion bearing or replace. Use no seal on the side of the bearing that faces into the diff. Pack that unsealed bearing extra full with Lucas Synthetic grease with antisieze.
5-6 races:
-all the above +
-change diff fluids, regrease diff outdrives, flip the outdrives
-refill shocks if needed, mine don't leak!
- disassemble CVD's clean and grease
-regrease wheel bearings, or replace as needed
-polish up the hinge pins
-flip the axels so the other side wears.
10 races:
-above plus
-replace shock oil
-replace shock orings, shock bladders, if needed
-replace DE skidplate
(an AE RC8 would need nearly every single plastic part replaced about now! LOLz, Xrays plastic will still be fresh about now)
-new body
-replace dog bone pins
This car is the tougest 1/8th scale I've driven so far. But better racers tear their stuff down alot anyway. You don't replce parts as fast as other cars, but you still need to maintain them.
Zerodefect is offline   Reply With Quote
Old 06-17-2010, 01:27 PM   #7
I agree with Zerodefect completely on his maintenance plan. I change shock oil continuously because I race to completely different tracks on a regular basis.
I can add is to watch your front and rear arms. They will warp with time and use. I cannot put a timeframe on it, but they will eventually. The first set did not last very long before they warped. Since then, I have removed shocks after each race day and that has helped. I am on same set since racing started in late March.
Watch your dog bone pins as well. They will flatten with time. Usually will change mine once or twice a season. Take care of those and you will not have to replace diff outdrives.
Clutch is just like any nitro car. I clean the bell and de-burr the shoes after each race to prolong life. I am anal and have never had a clutch bearing fail, but replace each week with $1 Avid's x 2.
In the '09, I have never had a problem with pinion bearings using the spacer. If you do normal maintenance, you will never have problems with them either.
Depending on how dusty the track you race on is, you main to check moveable parts more frequently.
I have uncountable gallons on my car now and have not had to replace any of the ball joints beside one that was damaged in a head on crash with someone flipped in a high speed straight. Mine still has less play then a brand new losi.
Awesome car, love mine. Was daunting at first with all of the setup options, especially active diffs and overdrive 41t diff. I can now get my car to work well others struggle.
Nitro cars are work, but well worth it.
RCMD is offline   Reply With Quote
Old 06-17-2010, 06:54 PM   #8
Exactly, except worse than that. They're often rebuilt between practice and qualifying. Then again between quals and the race. It's pretty retarded.
Old 06-17-2010, 07:12 PM   #9
that's wat u have to do if u are at the pinnacle of racing... the search for ultimate performance resulted in super light weight parts, coupled with extreme working stress, they sure won't last as long as my old toyota clunker...
