Old 06-16-2010, 08:20 AM   #1
mike881's Avatar
Default proper way to set camber/toe without setup station
How do you guys set you're camber and toe without a setup station? Please feel free to add your little tricks or whatever you got
mike881 is offline   Reply With Quote
Old 06-16-2010, 08:28 AM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Camber is easy. Just get yourself a camber gauge. Setting toe is more difficult. You can use the camber gauge turned on its side to set toe. Just position the front wheels against a flat vertical surface(like a wall or piece of wood) and use the camber gauge horizontally to set the toe off of the flat surface. Personally I just eyeball the toe.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-16-2010, 08:30 AM   #3
Yeah, eyeball the toe.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 06-16-2010, 08:30 AM   #4
mike881's Avatar
and can you explain what toe and camber does on the track?
Old 06-16-2010, 08:36 AM   #5
This will explain it better than anyone here can, most likely.
Hudy Set-up Book. This is a zip file. It will explain every setup theory imaginable.
http://www.hudy.net/xhudy/showfile.p...252739b1ad8c24
Old 06-16-2010, 08:39 AM   #6
siv06's Avatar
Download the Hudy Setup Guide - do a google search
all the answers you'll ever need !!
Neil
Whoops beat me to it lol..........
Xray Xb8 /D8T.
Bullitt 216
Spektrum/hitec
Pirahna
siv06 is offline   Reply With Quote
Old 06-16-2010, 11:18 AM   #7
Lille-bror's Avatar
Hi.
Here is my way to make those messurements (Make a Google translation):
http://rcfreaks.dk/forum/viewtopic.php?f=1&t=8435
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 06-16-2010, 02:11 PM   #8
with camber gauge and toe gauge
TEAM: http://www.offroadersonly.gr/
Kyosho Inferno ST-RR,Novarossi Plus 4T,Byron Fuels,Sanwa M11,Hitec 7954HV/ACE DS1313
DE Racing,Answer-RC,Ascendancy,TKO,Pro-Line,Fioroni,King Headz,K Factory,Protek,O'Donnell
the_winner is offline   Reply With Quote
Old 06-16-2010, 03:36 PM   #9
mblgjr's Avatar
Trader Rating: 86 (100%+)
Camber: Set the car at ride-height with the tires you intend to race with. Remove said tires/wheels; install naked-wheels w/no tires. Set camber to desired specs. (I do this because the tire sidewalls are always in the way of the camber gauge holding it off from the wheel face).
Toe: Rear is pretty much preset with bars on any car.
Front: Stand the car vertically on it's nose/front bumper. With the radio system on, read the toe as though it was "camber" now. Negative will be toe out; positive will be toe in. A carpenters square or square-cut board will suffice to hold the chassis against to ensure it's perpendicular to the work surface. Or you can just eyeball it by feel, you can feel it balance around vertical fairly well.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 06-16-2010, 04:29 PM   #10
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
beer can for camber and a long string for toe.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 06-17-2010, 05:37 AM   #11
fattyalan's Avatar
IPHONE APP!!!
i use at the track when i can be stuff taking out the station
app:
AppBox Pro
Hot Bodies D8
O.S V-spec EB mods
Spektrum DX3R
Nitro-X Fuel
fattyalan is offline   Reply With Quote
Old 06-17-2010, 07:49 AM   #12
Trader Rating: 119 (99%+)
Originally Posted by fattyalan View Post
IPHONE APP!!!
app:
AppBox Pro
lol i do the same with but with my DROID
skoalisbad4me is offline   Reply With Quote
Old 06-17-2010, 07:51 AM   #13
marshon50's Avatar
Great tip! Thanks! Looks like my r/c toolbox is now gonna include a square LOL!
Also, +1 on the phone app, on my HTC it's called the bubble. I've checked it vs a traditional level and it's spot on. Mine tells me the degrees off of level so I can get 2 degrees negative camber using my phone instead of my camber gauge...pretty trick
Thank you sponsors:
Werks Racing, 30% Race Blend Nitro Fuel, Werks B6 and Pro, B5 and Pro, B2, Pro Clutch
Hobby Pro USA, Agama USA, VP-Pro, Beta Racing Tires
Hobbymasters, Red Bank, NJ
Venom Group
marshon50 is offline   Reply With Quote
Old 06-18-2010, 02:25 PM   #14
Sein's Avatar
Just downloaded the bubble app. Thanks Guys!!!!!!!
Sein is offline   Reply With Quote
Old 06-18-2010, 08:33 PM   #15
rawdawgga's Avatar
thanks for the app but can someone post pics on how to use it for front toe thanks im a little slow
Thanks to my 2014 sponsors Mugen Seiki racing, Vp-pro USA, Murnan modified motors and maxy fuel
Mugen Mbx7 Murnan Modified Novarossi Beat plus 4
Mugen Mbx6tr Murnan modified Novarossi Beat 5
Mugen Mbx7 eco hobbywing esc and motor
rawdawgga is offline   Reply With Quote
