Old 06-14-2010, 06:47 PM   #1
Questions?? Super durable engine recommendation wanted
Can anyone recommend a super durable .18 buggy engine? This is for a Kyosho DBX (I know it will take some work to install in a DBX). It will be used for back yard fun in a very hot climate. I don't care about fuel economy but easy tuning is important. Would the OS .18 TZ be a good choice for this case? Anything more durable?
MattFL is offline   Reply With Quote
Old 06-14-2010, 07:02 PM   #2
Trader Rating: 12 (93%+)
get the cv-r. You will found out very quick the tz is tooo much. It stait hauls ass in a 1/10th car. You hit the gas and your on two wheels. The cv-r is plenty!
rcdude236 is offline   Reply With Quote
Old 06-14-2010, 07:25 PM   #3
Trader Rating: 27 (100%+)
why would you want to put a .18 in a 1/8 scale buggy?
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
ElitePaintWorkz@gmail.com
mist467 is offline   Reply With Quote
Old 06-14-2010, 07:43 PM   #4
triplebvalp's Avatar
Cause, it's not 1/8th scale:
http://www.amainhobbies.com/product_...R18-KT-6-Radio
triplebvalp is offline   Reply With Quote
Old 06-14-2010, 07:48 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
LOL the glory of RCTech. DBX is a 1/10 scale gas buggy.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-14-2010, 07:50 PM   #6
moeman's Avatar
Trader Rating: 26 (100%+)
I got a CVR in mine and it's tons of fun, runs good, and makes the ladies crazy!!!
moeman is offline   Reply With Quote
Old 06-15-2010, 05:37 AM   #7
Were you able to use the original DBX exhaust and manifold with the CV-R? I can't tell from the O.S. manual the size or location of the exhaust.
Old 06-15-2010, 07:35 AM   #8
Nothings durable is one dont take care of it.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-15-2010, 07:55 AM   #9
Of course, but with proper care some are still better than others. I would prefer to spend more time driving and less time and money fixing, so I am looking for the "Toyota" motor, not the "Ferarri" motor.
Old 06-15-2010, 08:09 AM   #10
moeman's Avatar
Yeah the manifold works, the exhaust is at a bit more of an angle because of all the motor spacing that is needed. You need the DBX OS motor mounts and some added spacing if you are to run a pullstart. I had to cut down the end of the crank to get it all to line up with the spur gear. I had the threaded shaft motor however.
Old 06-15-2010, 08:11 AM   #11
Xmod_Racer's Avatar
Send a message via AIM to Xmod_Racer Send a message via MSN to Xmod_Racer
I would say that the "Toyota" motor is a good idea. Just stay away from the "Toyota" throttle servo
TEAM WRCRC
Xmod_Racer is offline   Reply With Quote
Old 06-15-2010, 09:18 AM   #12
http://www.amainhobbies.com/product_...ide-Carburetor
http://www.amainhobbies.com/product_...-5-Port-Engine
Old 06-15-2010, 09:20 AM   #13
Thanks for the info, this is probably the way that I will go. Are the motor mounts DBX specific, or just standard OS mounts? Also to space for the pull starter, did you raise the motor higher, or have to slide it forward? Finally did you get the CV-R with the slide or rotary carb? Sorry for all the questions, if you could post a picture or two from the exhaust side that would be great!
Old 06-15-2010, 10:43 AM   #14
moeman's Avatar
The mounts are a specic fit to the DBX chassis. I spaced the motor up, and I got a rotary carb, but I'd prefer the slide carb. I'll try and gets some pics up. I bought my motor used to I just went with what I had.
Old 06-15-2010, 11:39 AM   #15
Did you get the mounts from Kyosho, or from OS? It sounds like that is the one part I really need to find. Thanks again!
