Old 06-14-2010, 02:31 PM   #1
Default xray 808 diff bearing
Is there any one out there that can help me sole the problem off the diff bearing i can only do one heat with them before they break why is this?
glen hants is offline   Reply With Quote
Old 06-14-2010, 05:07 PM   #2
1- there already is a thread for Xray
New XRAY 808
2- if you are only getting one heat from your bearings then you obvoiusly have other issues causing the failure.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 06-14-2010, 10:54 PM   #3
merdith6's Avatar
Default Try this...
When I was building my 808 for the first time I noticed there was play in the pinion assembly. So I put one medium sized silver shim on the pinion before I install the bearing, the one that touches the three retaining screws closest to the diff. that takes up the slack and reduces the impact on the bearings upon landing off a jump, in addition to closing the gap on the pinion diff contact and keeping the mesh consistent over the long haul. I then put one thin shim in between the bearing and the diff case, the plastic side, not the diff gear side, this prevents the mesh from closing too much. I hope this helps...you should get 4-5 race meets out of those bearings.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
Xray 808 E-Conversion Kit? Dookiman Electric Off-Road 467 04-26-2013 02:42 PM
New XRAY 808 - 2010 Specs Fas N furious Malaysian R/C Racers 156 09-02-2010 03:28 AM
Is your Xray 808 a P.O.S.? Toycar5 Nitro Off-Road 44 07-29-2008 10:50 AM
