Old 06-14-2010, 06:49 AM   #1
Default Fioroni clutch on a Losi 2.0 B
Hi Guys, I did post a similar question some time ago but I think i just confused myself & every one who read it.
In simple terms I want to run a Fioroni turbo clutch on my 2.0 B with a standard 13 tooth clutch bell not the standard Losi bell
from what i can see i need the FIO OT FR51 which pushes the shoes 2mm forward which i would have thought would aid the mesh.
There must be someone out there running a Fioroni turbo clutch on a standard clutch bell??
Losi 2.0 B Novarossi plus 4
Losi 2.0 B....in the making ; )....sold due to crazy UK brca lipo ruling : (
x Factory x6 sQ
los2 is offline   Reply With Quote
Old 06-14-2010, 07:41 AM   #2
travis4380's Avatar
Trader Rating: 17 (100%+)
To run the standard bell, you would need this engine mount to move the engine forward. Losi also makes one but I like the Kings Head one better. http://www.amainhobbies.com/product_...ge-Motor-Mount
Tekno SCT 410
Tekno EB48.2
Tekno NT48
http://www.showmerc.com/phpBB3/index.php
travis4380 is offline   Reply With Quote
Old 06-14-2010, 07:46 AM   #3
JAMMINKRAZY's Avatar
The King Headz mount would allow you to run a standard bell with the FR50. Question is, why would you want to? Losi bells work just dandy with the fioroni clutch.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-14-2010, 12:21 PM   #4
I do have the Fioroni adjustable engine mount so i have plenty of adjustment
Wanted to run a standard bell rather than a Losi bell due to cost of bearings & standard bells more readily available
Can you guys tell me your exact fioroni flywheel type & collet you are using on your 2.0 B
Fioroni kit hard to get hold of over here in the Uk so will need to get from 'amain' so dont want to waste time getting the wrong kit
Thanks agian guys
x Factory x6 sQ
Old 06-14-2010, 12:28 PM   #5
Thanks agian guys
I run the FR70 clutch kit on my losi's with losi clutch bells. You can use it with a standard bell but you will need to flip your mount to the forward position. I run the black carbon shoes with 1 hard and 2 regular(medium) springs.
http://www.amainhobbies.com/product_...-Clutch-System
http://www.amainhobbies.com/product_...utch-Springs-6
-Koby Kubrin-
Old 06-14-2010, 01:37 PM   #6
Thanks jamminkrazy
Is that with the Losi collet? also did you need to file the end of the collet to stop it poking through the flywheel to enable you to tighten the flywheel nut down fully?
x Factory x6 sQ
Old 06-14-2010, 02:41 PM   #7
Thanks jamminkrazy
I use a standard Novarossi style collet that is filed down like you described. You can use a losi collet, but the Novarossi style ones have a better fit. You will need a shim behind the collet if you use a losi one.
http://www.amainhobbies.com/product_...wheel-Collet-1
-Koby Kubrin-
Old 06-14-2010, 06:40 PM   #8
travis4380's Avatar
I run the fr-50 clutch kit on mine with stock collet and losi bell. as far as bearings you can get them for $1 each here. http://avidrc.com/
This is my clutch.
http://www.amainhobbies.com/product_...n-TTR-OFNA-etc
http://www.amainhobbies.com/product_...ch-Shoe-w-Shim
Tekno SCT 410
Tekno EB48.2
Tekno NT48
Old 06-14-2010, 07:06 PM   #9
This is my clutch.
That combo is exactly the same as the FR70 kit I linked above. The FR70 is just a combination of the FR50 flywheel and FR52 clutch shoes in one package. Great clutch!
-Koby Kubrin-
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi / Fioroni clutch problem los2 Nitro Off-Road 8 06-04-2010 12:19 PM
>>> Race Ready PRO Losi 8IGHT Package Deal -- MUST SEE <<< RcOneNitro R/C Items: For Sale/Trade 69 03-02-2009 09:39 PM
