Old 06-14-2010, 02:25 AM   #1
sialek's Avatar
Default sirio cl7b big problem !
Hi All,
I am new at this forum but I need a bit help. I own a sirio CL7b long stroke enigne. It has about 1.5 galon. It burns plugs all the time, I even add shrims (2x 0.1mm) to make it "looser" but it stil nothing, engine runs great for 10 minuts and cut off ( turn down) ale the plug is broken. It's perfectly set-ed up by a a-main guy here in poland, it keeps 110 C degrees all the time. I tried to use turbo plugs (OS P3, oS P4, Sirio 6, Sirio 7, SIIM 7, SIIM 8, Novarossi 5, Novarossi 6, RB 6) and after that i tried to use normal plugs ( have 2 buttons) - OS no.8, OS A5, OS R5, Novarrosi C5, novarossi C6 and others. INSIDE the enigne i perfectly CLEAN AND look great, it has great compression. The carbureator has been sealed really well, no leaks. I use ofna jp-3 muffer. I use power safe 25% fuel, 12% synthetic oil but i also tried byron 25% race fuel and it was the same story. Has been broken in by head cycle 9 tanks method. Need photos of inside? tell me i will send them here. Please give me some clue?
In addition I can say that for about half galon after breaking in it runed great. The problems start after that.
sialek is offline   Reply With Quote
Old 06-14-2010, 02:38 AM   #2
RUNNINONMT's Avatar
it may be running too rich.
RUNNINONMT is offline   Reply With Quote
Old 06-14-2010, 04:53 AM   #3
sialek's Avatar
nope, it runs good fuel mix. Not too reach not to low.
Old 06-14-2010, 12:04 PM   #4
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
new to nitro yet you are 100% sure the tune is perfect.
okay, assuming you are correct i would try the hottest plug you can find an os p3 would be a good start,
if it is still acting up i would look at the fuel. did the problems begin about the time you cracked open a new bottle of fuel?
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 06-14-2010, 12:09 PM   #5
neobart's Avatar
I would check the rod and crank for play, that can blow plugs.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 06-14-2010, 12:33 PM   #6
RC-ZOMBIE's Avatar
Did it start after you put a regular plug in it? you cant interchange turbo and regular you may need a new head button.
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 06-14-2010, 01:25 PM   #7
smittyusmc's Avatar
The CL7B come with both turbo and standard head buttons.
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 06-14-2010, 01:55 PM   #8
RC-ZOMBIE's Avatar
Sorry didnt know that sorry
Old 06-14-2010, 02:19 PM   #9
22Racer's Avatar
Trader Rating: 67 (100%+)
Almost every Cl7b I've rebuilt needed a new rear bearing. Look at the piston through the exhaust port and look for very small scratches.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 06-14-2010, 04:03 PM   #10
KThatcher's Avatar
Trader Rating: 64 (100%+)
Sounds like a bearing problem
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 06-15-2010, 02:13 AM   #11
sialek's Avatar
bearing is gone ;/ incredible one of bearing balls "breake in 2 halfs " i have scrathes on piston and sleeve. Tell me now where I can get a bearing and rebuild set because that one is probably dead (scratches). Can't get it why it happend so fast ;| always get about 3 gallons before bearing change.
Tell me what to do, 1st option - new bearing and try to run it, 2nd- engine to waste paper basket, it doesn't make sens to rebuild it full ( piston, slave, conrod) because i payed (new one) 160$ for it. (50$ conrod, 120$ piston + slave)
photos of it : http : // wyslijto . pl / files / download / 98ypp4ceo1 (DELETE THE SPACES)
to download photos use your left mouse button and clic on " silnik.rar (rozmiar: 2,2 MB ) " !
Old 06-15-2010, 02:46 PM   #12
22Racer's Avatar
I didn't look at the pics but if they are just small scratches just a repinch and it will run like a champ. If it has a big gouge it's probably toast.
I charge $28.95 for a Tko ceramic bearing and $37.00 for the rebuild, pinch etc. return shipping included. I think there may be a problem with the block machining on those motors causing it or just terrible bearings. I have seen at least 5 engines just like yours, one with chunks of the balls missing.
Rex
CL7B & V-Spec long term viability (not a "which is faster" thread) deus1978 Nitro Off-Road 9 10-10-2008 10:16 AM
