Old 06-13-2010, 06:33 PM   #1
Default DBX loose rod, what next?
Discovered today that my DBX has a loose rod. The lower end is visibly loose and I can see where it has been rubbing on the engine case, which I'm sure is the tick-tick-tick sound I've been hearing. The catch is, I can't find rods, head gaskets or wrist pin clips for sale anywhere for the DBX. Can anyone tell me where I can get just these parts? The engine still has fantastic compression so I don't think I'm going to need a piston or cylinder.
MattFL is offline   Reply With Quote
Old 06-13-2010, 06:47 PM   #2
Trader Rating: 27 (100%+)
just to let you know if your rod is that sloppy that it was rubbing on the case or backplate your rear bearing is prob bad. When the bearing goes bad it wears the rod and then you start trashing the rest of the motor.
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
ElitePaintWorkz@gmail.com
mist467 is offline   Reply With Quote
Old 06-13-2010, 06:50 PM   #3
moeman's Avatar
Trader Rating: 26 (100%+)
Ebay a new motor for $89. I've seen them cheap on there.
moeman is offline   Reply With Quote
Old 06-13-2010, 07:07 PM   #4
Thanks for the tip, I'll be sure to replace the bearings at the same time. Any suggestions on which ones will fit?
This thing seems to have let go pretty early, just short of 2.5-gal through it..
