Old 06-15-2010, 04:25 PM   #16
Integra's Avatar
I vent as per how much the foam needs.
Old 06-15-2010, 04:25 PM   #17
trevor15308's Avatar
Send a message via Yahoo to trevor15308
i use just stickers on the rim hole then i put two in the tires
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 06-15-2010, 04:31 PM   #18
Arco's Avatar
Absolutely right, I start with the small punch x 4 and increase the diameter if needed.
OverdriveRC.com
"Promote and Support"
Arco is offline   Reply With Quote
Old 06-15-2010, 05:02 PM   #19
Arco's Avatar
This might help a lot of guys out...In the detailed description of our wheels and tire section, it will tell you if there are pre-punched breather holes or not.
OverdriveRC.com
Old 06-15-2010, 05:02 PM   #20
jammin32j's Avatar
I use the closed cell foams so I can get away with just two holes. To be honest when I used the softer foams I only used two holes and didn't notice a difference. But that could be just my lack of experience.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 06-15-2010, 05:16 PM   #21
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed! But I only ever use 2 holes. I just use different diameter holes depending on the foam. Truggy tires get bigger holes than buggy tires do right off the bat. Then I adjust from there depending on foam.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-15-2010, 05:46 PM   #22
Arco's Avatar
Be honest now guys, have you ever tried 4 holes...If not try it.
OverdriveRC.com
Old 06-15-2010, 05:56 PM   #23
Yes, I have and noticed absolutely no difference between 2 and 4 holes. As long as they get the job done, I'd rather have fewer holes in my tires.
-Koby Kubrin-
Old 06-15-2010, 06:19 PM   #24
Arco's Avatar
Cool that it works for you.
I have found that 4 work better for me because when one is compressed, (sealed to the ground) having 3 left open disperses the pressure in a more linear fashion.
OverdriveRC.com
Old 06-15-2010, 07:33 PM   #25
I honestly don't think into it that far. I just punch some holes in my tires so air can get out.
-Koby Kubrin-
Old 06-15-2010, 08:12 PM   #26
jammin32j's Avatar
+1 to me the fewer holes you can put in your tires and still have them effective the better off you will be.
VP Pro, Agama
Jeremy Davis
Old 06-15-2010, 08:48 PM   #27
Arco's Avatar
Yep, and 10 years ago I ran oily 15% heli fuel in my surface rigs because they ran on it... And it was under $10.00 a gallon....Then when I found a forum of people to talk to, that all ended.....I truly do understand.
OverdriveRC.com
Old 06-15-2010, 08:59 PM   #28
LOL I'm no rookie bud. I don't need a forum to create an opinion about things. I've been doing this awhile. I just like as few holes in my tires as possible. Less holes for dirt to get into on the track or water to get into when washing them. If 2 holes will vent the air enough(they do), I'd much rather have that than 4 holes. Anyway, run your tires how you want. 2 holes are perfectly adequate especially with the newer foams that don't vent as much air. I don't think it really matters how many holes you use. I use 2, you use 4. That's cool, but you won't convince me that 4 is better.
-Koby Kubrin-
Old 06-15-2010, 09:30 PM   #29
Arco's Avatar
It's all good, but you and I both know that you're going to try 4 smallish holes on your very next set.
Just think of me as you're adding those two extra holes.
OverdriveRC.com
Old 06-15-2010, 09:45 PM   #30
Not gonna happen! I've already done it and saw no positive difference.
-Koby Kubrin-
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
AKA tires ALG Nitro Off-Road 1793 11-04-2016 06:37 AM
ProLine foams HookaMega Nitro Off-Road 133 09-08-2011 02:13 PM
