Fioroni clutch on a Losi 2.0 B
Hi Guys, I did post a similar question some time ago but I think i just confused myself & every one who read it.
In simple terms I want to run a Fioroni turbo clutch on my 2.0 B with a standard 13 tooth clutch bell not the standard Losi bell
from what i can see i need the FIO OT FR51 which pushes the shoes 2mm forward which i would have thought would aid the mesh.
There must be someone out there running a Fioroni turbo clutch on a standard clutch bell??
To run the standard bell, you would need this engine mount to move the engine forward. Losi also makes one but I like the Kings Head one better. http://www.amainhobbies.com/product_...ge-Motor-Mount
I do have the Fioroni adjustable engine mount so i have plenty of adjustment
Wanted to run a standard bell rather than a Losi bell due to cost of bearings & standard bells more readily available
Can you guys tell me your exact fioroni flywheel type & collet you are using on your 2.0 B
Fioroni kit hard to get hold of over here in the Uk so will need to get from 'amain' so dont want to waste time getting the wrong kit
Thanks agian guys
Thanks agian guys
Thanks agian guys
Thanks agian guys
http://www.amainhobbies.com/product_...-Clutch-System
http://www.amainhobbies.com/product_...utch-Springs-6
Thanks jamminkrazy
Is that with the Losi collet? also did you need to file the end of the collet to stop it poking through the flywheel to enable you to tighten the flywheel nut down fully?
http://www.amainhobbies.com/product_...wheel-Collet-1
I run the fr-50 clutch kit on mine with stock collet and losi bell. as far as bearings you can get them for $1 each here. http://avidrc.com/
This is my clutch.
http://www.amainhobbies.com/product_...n-TTR-OFNA-etc
http://www.amainhobbies.com/product_...ch-Shoe-w-Shim
This is my clutch.
This is my clutch.
This is my clutch.
