Old 06-13-2010, 01:14 PM   #16
Trader Rating: 12 (93%+)
get some callipers and measure out something that is somewere between .7mm and 1mm and try and stick in the hole with a tight fit.
rcdude236 is offline   Reply With Quote
Old 06-13-2010, 01:20 PM   #17
what hole do I stick it down?
K-man 15 is offline   Reply With Quote
Old 06-13-2010, 01:30 PM   #18
you close the carb shut and the little arch in the carb. you wanna put in in the middle.
http://img525.imageshack.us/i/picture001km0.jpg/
Old 06-13-2010, 01:39 PM   #19
that seems to be okay
Old 06-13-2010, 01:43 PM   #20
just look at a ruler at 1mm and than just kinda look at your idle. Go in or out with it. Than put your hsn and lsn and stock settings and try starting it. If it dont start than lean out your needle slowly till it does. THan do the 7 second pinch thing.
Old 06-13-2010, 01:44 PM   #21
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
If theres any way possible, try to take it to a race track and seek help there too. Kinda confusiing over the net. Its one of those things thats best learned in person. Just my .02 cents
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
Old 06-14-2010, 06:57 PM   #22
Thanks for the help guys! I got it running. The tune isn't quite right but I am working on that and hopefully I will get it.
Old 06-14-2010, 06:59 PM   #23
just set the lsn like i told you and adjust your hsn to that. Once you have your lsn set dont play with it. Just play with your hsn.
engine troubles!! kn0bbyba11 Nitro Off-Road 13 05-23-2008 11:39 PM
engine troubles rcbc Nitro Off-Road 8 05-15-2008 01:52 PM
MAJOR Engine troubles (i think...) new to rc cars Nitro Off-Road 33 04-16-2008 11:53 PM
Engine Troubles PLZ HELP!! Hoggy Nitro On-Road 6 06-27-2005 10:43 PM
