Old 06-12-2010, 07:22 PM   #1
hdcruzer's Avatar
Default Diff. Shim Question
How are you guys shimming your rear diffs on the 8T 2.0s? The owners manual isnt close. When I took mine apart it had 2 .25s on each side. Still have a problem with them blowing. Any tips ? Thanks in advance.....
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 06-12-2010, 07:38 PM   #2
l3asher's Avatar
Couple of things, once you blow the gears you need to repace the gearbox when rebuilding. I would also run the alumnium inserts and get rid of the plastic ones, they allow for some unwanted flex. When installing the new pinion gear pull in all the way forward when installing the coupler to remove any slack. All gear boxes are differant but I have 3 shims on the left and 2 on the right. Some times it feels notchy but it will wear in just fine.
l3asher is offline   Reply With Quote
diff rebuild question ace921000 Nitro Off-Road 8 01-18-2009 07:42 PM
