Old 06-10-2010, 08:09 PM   #1
Default is there a way to keep your front engine bearing clean?
What do you suggest i do to keep the front bearing clean? Took my flywheel off and it was full of crap. And if the front bearing is seeping even just a little oil, it works it's way into the bearing and then it's no good. I am replacing front bearings way to often. Is there a way to keep it clean behind the flywheel?
To be fair i used a larger collet this time that pulled the flywheel off a little further. But it still does it with my mugen one. Should i not put the washer behind the collet?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-10-2010, 08:13 PM   #2
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Dirt on the outside of the bearing wont hurt anything unless you spray it with a cleaner. The cleaner will take the dirt from the outside and let it get inside. Just wipe the bearing off with a dry towel occasionally.
RCmayor is offline   Reply With Quote
Old 06-10-2010, 08:19 PM   #3
you get one guess on what i did before i posted this thread. But you only get one guess....
i will give you a hint
$*&T! I knew what i was doing was wrong. But it was to gritty anyway, and left a small pudle of oil under the front of my engine. That stupid red clay dirt gets in everything.
Mugen
Old 06-10-2010, 08:56 PM   #4
RCmayor's Avatar
Ya, just don't run the engine like that. Tear it down, take the front/rear bearings out. Flush everything under water then WD40. Water is cheaper and is a good cleaner, just don't leave water on anything for even a couple minutes. You may need to pop off the front bearing seal to get everything out.
Old 06-10-2010, 09:38 PM   #5
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Rb Engine Protect designed for this:
http://www.redrc.net/2010/02/rb-engine-protect-system/
cpaurl
rallyebmx is offline   Reply With Quote
Old 06-10-2010, 11:13 PM   #6
CosworthDriver's Avatar
Novarossi makes something similar. Check out the Novarossi homepage for more info.
Cheers - Tommy Møller Hansen
www.grcc.dk - www.brc-racing.dk - www.smorc.dk
Hong Nor X2 CRT, OS FS56 alpha, RB WS7-III L2G, Spektrum DX3R
Serpent F180, Mega FT-28
Xray T2R Pro, Venom VMX450, Aquacraft UL1
CosworthDriver is offline   Reply With Quote
Old 06-10-2010, 11:23 PM   #7
NOVA 29063
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 06-11-2010, 04:29 AM   #8
Ok, stupid question here.
the bearing will still be good if i pop off the seal? I also have a brand new front bearing in another engine that has about 2 tanks on it. It wouldn't hurt the bearing if i took it out and put it in the engine with the bad bearing? I have done it before, but sometimes i think transplanting the bearing is not good for it, and maybe it won't seat right? Am i wrong? Or am i just being paranoid
i always thought taking off the seal on engine bearings was bad for it.
Mugen
Old 06-11-2010, 08:24 AM   #9
CKmaxx's Avatar
I swap bearings all the time, new or used. As long as the used one you are putting in is still good.
Removing the seal isn't a bad thing. Just take your time taking it out and it will be fine.
Tekno NT48.3 and NB48.4 powered by OS Engines
Tekno ET48.3 powered by Tekin
CKmaxx is offline   Reply With Quote
Old 06-11-2010, 08:27 AM   #10
Frank L's Avatar
Trader Rating: 148 (100%+)
Engine bearings do wear out. If it's leaking more than just a little then replace it. I find that I usually go through front earings every 4-5 gallons. Just replace them.
What do you guys think of this Werk's .21 Engine? Garet Jax Nitro Off-Road 82 07-20-2016 04:40 AM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
