Old 06-10-2010, 11:05 AM   #1
Post newbie, and exhaust Q
hey, im new on the forum, but have been into RC nitro trucks for about 2 years, im 16 so, i don't know much.
Im running a TRX 2.5 in a custom chassis(aluminum) with a mix of blue anodized aluminium and plastic, as well as a custom exhaust..
i want to change the Exhaust so it's sounds deeper (like aftermarket exhaust on a car). Right now it's your typical high pitched sqeaul. is it even possible to make an exhaust like this? How couldm i go about doing this?
Thank you,
Xavier
blackjack233 is offline   Reply With Quote
Old 06-10-2010, 05:15 PM   #2
traxxastar21's Avatar
its a two stroke you cant really get that deep rumble like out of a 4 poke but try some exhausts i guess but you are probably going to live with the sound
JATO "Jet Assisted Take Off"
traxxastar21 is offline   Reply With Quote
Old 06-10-2010, 05:51 PM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
Pipes made from thicker aluminum will give a slightly lower pitched sound, but it will still have a very high pitch with that Small block you're mounting it to..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 06-10-2010, 06:13 PM   #4
would it be possible to make a custom one, with a 1/2 inch from the engine, then to a 1 inch body wiht baffleing(and hole for backpressure line) and then to a 3/4(or slightly smaller) output ? would that help
Old 06-10-2010, 06:22 PM   #5
jjshbetz11's Avatar
Is this a stock TRX pipe? If it is get the single chamber TRX pipe and if you don't race bore out the stinger.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 06-10-2010, 06:30 PM   #6
no, i bought used with a cracked(didn't know till i washed with acetone) alum. exhaust, with that it's 1/4inch to 1inch(bore) to 1/4inch output... it's a shitty thing, but i got it all for like 100$ a year and a half ago..
Old 06-10-2010, 06:33 PM   #7
jjshbetz11's Avatar
if im following you the output is the stinger. I take the quarter inch is outer diameter? Sounds like a big block pipe.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 06-10-2010, 06:34 PM   #8
what do you mena by stinger?? is that the stock exhaust?
Old 06-10-2010, 06:35 PM   #9
jjshbetz11's Avatar
Does it have a name on the pipe?
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 06-10-2010, 06:36 PM   #10
jjshbetz11's Avatar
The stinger is where the actual exhaust would come out at. You got a header, then the "pipe" and the stinger comes off of the pipe.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 06-10-2010, 06:37 PM   #11
no, what's mounted on it now is a custom alum. one, the stock black one came with it if i wanted to put it back on.
i'd post pictures, but the site has a min. # of posts needed -.-
Old 06-10-2010, 06:39 PM   #12
jjshbetz11's Avatar
Custom? Would take a hella CNC machine for that.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 06-10-2010, 06:40 PM   #13
not CNC, welded alum. it's weird i know, the sound wails like and SoB..
Old 06-10-2010, 06:42 PM   #14
jjshbetz11's Avatar
I would personally put the OG pipe back on it. Alot of science in tuned pipes and for one to just make one could really hurt performance.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 06-10-2010, 06:44 PM   #15
so the OG, is the stock one?
Newbie questions WillB Rookie Zone 15 02-08-2005 08:21 AM
