Old 06-09-2010, 04:38 PM   #1
Tbizz's Avatar
Send a message via AIM to Tbizz
Questions?? Fuel Tubing Size
Hey everyone...dumb question....
Do different size engines require different fuel tubing sizes? I just noticed that I've got two different inner diameter size fuel tubing lines. Is the smaller size generally for .12-.18 engines and the other for .21 and up or is it safe to use the smaller tubing on a .21?
Thanks,
Tony
Tbizz is offline   Reply With Quote
Old 06-09-2010, 05:45 PM   #2
trevor15308's Avatar
Send a message via Yahoo to trevor15308
u can use any fuel tubing on any motor
it doesnt matter
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 06-09-2010, 06:04 PM   #3
jeff_ellis_9's Avatar
this is nice to know, thanks
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 06-09-2010, 06:38 PM   #4
305M3's Avatar
Trader Rating: 40 (100%+)
Yes, but there are different sizes. I learned the hard way trying to replace the fuel tubing going into my tank with size "jumbo", as opposed to medium.
Size medium was a lot easier to install and maintains a tight seal.
305M3 is offline   Reply With Quote
Old 06-09-2010, 06:39 PM   #5
I've got a question about tubing too. Does the length matter. In my old engine it seemed like when I cut the tubing short I had problems. The engine was almost dead so I don't know if it was my imagination or not.
Can I cut the tubing as short as I want with no problems?
bevofrancis is offline   Reply With Quote
Old 06-09-2010, 06:46 PM   #6
jjshbetz11's Avatar
fuel length will have a effect on run time, the shorter the less runtime. More fuel tubing can hold more volume, after getting mill up to temp(with long fuel tubing) refuel and you will actually be holding more fuel than legally allowed. But on the negative side, longer tube can also hold more air.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 06-09-2010, 07:39 PM   #7
Fuel Length is the difference.
theblackbart is offline   Reply With Quote
Old 06-09-2010, 07:50 PM   #8
merdith6's Avatar
Default I like
the dubro large tubing for airplanes. It helps get max fuel when needed. If you have a clunk tank then medium. You can get a huge 30 ft roll of it for 25 bucks. It will last forever...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 06-09-2010, 08:13 PM   #9
Lille-bror's Avatar
Hi.
Remember that you need approx. 20 cm extra tube to have 1 ml more fuel.
Allways use the same inner diameter tube all over. Otherwise you can have tuning issues.
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
can I replace the fuel line on my losi tank? markt311 Nitro Off-Road 20 07-31-2009 12:15 AM
Fuel tube length!!!!!!! JPierson Nitro Off-Road 21 07-01-2009 11:02 PM
newb question but can you drill holes in your fuel tank busta774 Nitro Off-Road 10 04-13-2008 08:44 PM
Engine Temperature CHANGES with fuel level? gonsped Nitro On-Road 7 01-04-2004 09:08 AM
