Old 05-04-2011, 01:30 AM   #121
I wonder about the rear center driveshaft and rear chassis brace
pdmustgt is offline   Reply With Quote
Old 05-04-2011, 02:02 AM   #122
JsK
JsK's Avatar
The driveline gets a 3mm shim at the pinion and I would assume that the mounting pocket for the chassis brace would be offset 3mm to the rear.
JsK is offline   Reply With Quote
Old 05-04-2011, 03:58 AM   #123
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
I have been told by a few other team drivers the normal rear center drive shaft is fine. Fits good and doesn't need to be longer. The rear chassis brace mounting hole is fine or else they would have added a new rear chassis brace to the update kit..
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 05-04-2011, 08:00 AM   #124
Trader Rating: 49 (100%+)
Originally Posted by Quad Racer 34 View Post
What about the "newest" design Maifield and the team has been testing ( they ran it at neo) with it giving them more droop? What about that setup? Did this one work better or is this it?
I had this same though when I saw these released. I know a local team driver who already has these parts. And just a week NEO supposedly mayfield had gotten new ones to try. Must be the ones he got didn't pan out, or at least didn't perform as well as these originals???
cleblanc is offline   Reply With Quote
Old 05-04-2011, 09:22 AM   #125
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
No change is needed to the driveshaft or the chassis brace. The slot in the center diff outdrive is long enough to absorb the difference in length. The new chassis has the brace mount in the same place relative to the rear gearbox, so the same brace can be used.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 02-12-2012, 07:45 PM   #126
b4maz's Avatar
Trader Rating: 8 (90%+)
From the Montpellier GP this weekend. THere are some notches in the front suspension arms.
Tons of speed run videos and information:
www.fastestrc.blogspot.com/
b4maz is offline   Reply With Quote
Old 02-12-2012, 07:49 PM   #127
Jammin57's Avatar
Trader Rating: 120 (100%+)
They are only notched so when at fool droop the plastic shock retainer doesn't get pushed up and have a chance to come off the shock end
Jammin57 is offline   Reply With Quote
Old 02-12-2012, 07:50 PM   #128
b4maz's Avatar
I figured that but i dont know if this is going to be a running change or a new part number for the arms.
Old 02-12-2012, 09:44 PM   #129
Trader Rating: 21 (100%+)
This the first I've seen this being done. I personally havent had a problem with my shock retainers poping out.
Kyosho STRR EVO.2 / Hitec 7954/7950
Kyosho TKI3.5 KO servos
TEAM COMPTON RACING
OS Speed VZB spec 2 worlds edition / Novarossi Legend 4 / Novarossi Elite 5
FUTABA 4PKS
rcmoe is offline   Reply With Quote
Old 02-13-2012, 11:18 AM   #130
b4maz's Avatar
