Old 04-26-2011, 06:25 AM   #106
b4maz's Avatar
Trader Rating: 8 (90%+)
Originally Posted by ted05 View Post
yes i am using nanda racing shock end ,,, works VERY GOOD more droop and nice to jump
Do you have a link to these parts?
Tons of speed run videos and information:
www.fastestrc.blogspot.com/
b4maz is offline   Reply With Quote
Old 04-30-2011, 09:53 AM   #107
b4maz's Avatar
All new RC8 parts released.
RC8B Upgrade Parts
April 30, 2011
Based on the parts used by our Team Drivers at Motorama, CRCRC Winter Midwest Nitro Champs, and the IFMAR 1:8 Worlds in Thailand, these team-tested and raced parts are now available to everyone and will substantially improve the performance of your RC8B.
RC8B Upgrade Parts
Parts Availability: June 2011
UPC Part # Description MSRP
784695894761 89476 RC8B +3mm Chassis $99.99
784695894877 89477 RCB Light Outdrive, front $19.99
784695894785 89478 RCB Light Outdrive, rear $19.99
784695894792 89479 RC8B Upgrade Front Arms $16.99
784695894808 89480 RC8B Upgrade Rear Arms $16.99
784695894815 89481 RC8B Low B Plate (includes inserts) $19.99
784695894822 89482 RC8B Low B Plate Insert $2.99
784695894839 89483 RC8B Upgrade Front Tower $25.99
784695894846 89484 RC8B Upgrade Rear Tower $29.99
784695894853 89485 RC8B Aluminum Steering Posts $10.99
784695894860 89486 RC8B Rear Swaybar Kit. (Use with #89480 Upgrade Rear Arms.) Includes rear swaybars 2.5, 2.6, 2.7, 2.8, ball joints, set screws, swaybar retainer eyelets $18.99
784695894877 89487 RC8B Rear Swaybar, 2.5 green $3.99
784695894884 89488 RC8B Rear Swaybar, 2.6 white $3.99
784695894891 89489 RC8B Rear Swaybar, 2.7 blue $3.99
784695894907 89490 RC8B Rear Swaybar, 2.8 yellow $3.99
784695894914 89491 RC8B Suspension Upgrade Kit. Includes front and rear towers, modified front and rear upper and lower arms, straight eyelets, M3 x 22 button head cap screws $59.99
Old 04-30-2011, 10:59 AM   #108
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
What about the "newest" design Maifield and the team has been testing ( they ran it at neo) with it giving them more droop? What about that setup? Did this one work better or is this it?
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 04-30-2011, 11:11 AM   #109
dragracechief's Avatar
RC8B Upgrade Parts
April 30, 2011
RC8B Upgrade Parts
Thats exciting, looks to me like they did a good job with the new parts including some that were unexpected. Sould make good buggy even better.
dragracechief is offline   Reply With Quote
Old 04-30-2011, 11:47 AM   #110
b4maz's Avatar
I think this is built into the shock tower. Instead of using longer eyelits they made the shock tower shorter to extend the droop.
Old 04-30-2011, 11:58 AM   #111
Get ready for a lot of action on this and the buggy thread!
Old 05-03-2011, 07:02 AM   #112
b4maz's Avatar
There is a front and rear outdrive now. It looks like the front is longer than the rear. I thought the problem with the RC8 was bending of the front drive shafts because the front outdrives were too long. Should the front outdrives be shorter than the rears?
Old 05-03-2011, 09:55 AM   #113
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
It's the other way around. The new front outdrives are the same length as the original ones, and the rear outdrives are now shorter.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 05-03-2011, 09:59 AM   #114
b4maz's Avatar
Shouldnt the front ones be shorter too?
Old 05-03-2011, 10:09 AM   #115
I believe they are asking because some people bend the front drive shafts.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 05-03-2011, 10:11 AM   #116
b4maz's Avatar
Yes. Or use the shorter ones on the front.
Old 05-03-2011, 10:17 AM   #117
Maybe with the new suspension parts this isn't even a issue.
Old 05-03-2011, 08:28 PM   #118
Mlbracing's Avatar
Am I crazy, or are there less holes for the radio tray in the new chassis?
~ Team Associated ~ Jconcepts ~ Byrons Fuel ~
Thanks to my dad and everyone who helps us out!
Mlbracing is offline   Reply With Quote
Old 05-03-2011, 11:41 PM   #119
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Looks to be one less hole for the radio tray. I count 6 instead of the orginal 7
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 05-03-2011, 11:43 PM   #120
andrew-01's Avatar
Trader Rating: 22 (100%+)
It looks like they're all there, comparing to the 89000 chassis.
The 2 diagonal holes below the throttle/brake servo, and the other hole in the back corner, plus the servo holes.
One thing, as someone else had mentioned was the side 'rock guard plates'. The other chassis' have 3 holes on the side angle of the chassis, this new one has 2 holes though.
I wonder if we will see new 'rock guard plates' to utilize the chamfer or angled trailing edge of the chassis.
ANDRXW.com
andrew-01 is offline   Reply With Quote
