Post your favorite setup for Losi 8ight t 2.0
Feel free to skip the ones you don't know off the top of your head. I just want to get a feel for the basic best setups. I feel like i can drive better than my car currently handles. I'm lacking in knowing setup.
1. Post track type and conditions
2. Shock oil weight, pistons, springs front and back
3. Diff oils
4. Sway bars
5. Ride height
6. camber
7. toe
8. caster
9. bump steer
10. tires
11. shock position
12. Clutch and springs
13. The one thing that finally dialed your car in
Mine so far
1. Dirt, semi loose to hooked up
2. front-40wt/55 black spring back-35wt/56 gray
3. 7/10/3 - f/c/r
4. 2.3mm
5. 39mm front 42mm back
6. -1 degrees front -2 back
7. 2 out front - 3.5 degrees back
8. stock
9. Down
10. city beams!
11. front - 2/middle back 3/Middle
12. dynamite max life silver and gold springs. I need to change this!
13. Nothing yet thats why i started this thread LOL. Actually the city beam combo makes it turn great!
3. Diff oils
4. Sway bars
5. Ride height
6. camber
7. toe
8. caster
9. bump steer
10. tires
11. shock position
Mine so far
3. 7/10/3 - f/c/r
4. 2.3mm
8. stock
9. Down
10. city beams!
Nice idea on posting the actual sheet.
Come on. Its ok to share your secrets. This hobby is about helping others!
1. Use it in big open blue groove track, and blown out, loomy
2. Front: Black,37.5 55/Back: Silver, 30 56
3. 7/10/2
4. 2.3 front, 2.0 back
5. F-39 B-42
6. F- -1 B- -2
7. F- 3 b-3
8. Stock
9. Down
10. City blocks or Gridirons at blue groove, Ibeams in blown out or if it has top soil
11. front-2 middle, R V2 tower, 4 middle
12. 2 Alum 2 Comp, 2 gold 2 green, Alum Flywheel
13. Droop F 107 R 127
14 what dialed my truck in was moving from 40 wt shock oil in the front to 37.5 and moving my droop from 110 to 107
3. 7/10/2
5. F-39 B-42
6. F- -1 B- -2
7. F- 3 b-3
8. Stock
9. Down
how can i get my RTR to want to turn better in corners, it push's like crazy ?? i drove another racers brand new race roller last night and his truggy does not have the problem my truggy has...
im going to cry now
im going to cry now
http://losi.com/ProdInfo/Files/8IGHT...-challenge.pdf
Check out the Mike Truhe Nitro Challenge setup. That is the one I ran most of the time on the 1.0 truggy.
