Old 06-06-2010, 01:50 PM   #1
Default how many of you oil the outer and inner element of your air filter?
I used to oil both the inner and outer parts of the air filter until i had multiple people recommend that i just oil the inner filter. I change my filters every couple of tanks, and somtimes you can see the red dirt from the track on the innermost part of the inner filter. I don't ever actually see dirt in my engine even when i break it down. My question is, should i oil the inner and outer to catch more dirt? To me it would seem that the oil on the outer filter would attract much more dirt and make it hard for your engine to run. Maybe a filter cover for the prefilter? I use losi filters with a x ray neck and has worked very well and i buy new filters quite regular, and i oil them pretty good.
How do some of you do it? would like some suggestions.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-06-2010, 01:53 PM   #2
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
i oil both. i always have. if not the dirt can get sucked through and onto the inner filter therefore make it easier for it to get into your engine. Let it all attract on the outer and change it when it gets dirty.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 06-06-2010, 01:56 PM   #3
Trader Rating: 520 (100%+)
Well, I learned a trick from a nitro vet, and he oils the inner completely and the inside of the outer, that way the big stuff wont stick and just clog the outer filter. It works for me, and he's been doing that way for years.
flame56mx is offline   Reply With Quote
Old 06-06-2010, 01:58 PM   #4
wow... never thought of doing that. that makes way more sense
Dylan Gerard
Old 06-06-2010, 02:00 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Oil both and change them often. Dirt will get stuck to the outside of the outer, but if you change them often, it won't cause an issue and you're engine will thank you.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-06-2010, 02:05 PM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
I oil the inner only and then I put the outer over it and squeeze out the excess oil from the inner to the outer. Then I wrap with petwrap or self adhesive bandage. Works great and I cut off the petwrap when it gets caked and then I have a brand new shiny clean filter for my mains
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-06-2010, 02:22 PM   #7
all good answers. Thanks everyone.
Mugen
Old 06-06-2010, 02:26 PM   #8
Charles Godwin's Avatar
One thing i always do though is, use some clear silicone grease on the inner airfilter (on both side edges) where it gets held in position by the housing. You'd be fairly amazed by how much crap the grease traps.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 06-06-2010, 02:31 PM   #9
Trader Rating: 12 (93%+)
i oil both inner and outer and slap it on.
rcdude236 is offline   Reply With Quote
Old 06-06-2010, 02:53 PM   #10
22Racer's Avatar
Trader Rating: 67 (100%+)
I started flipping the outer inside out and put a light coat on it. The best way I've found to do it, depends on the filter and brand.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 06-06-2010, 04:07 PM   #11
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
i like oiling both to be safe .
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-06-2010, 04:12 PM   #12
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I oil both, but post #3 and #6 make great sense! Excellent ideas both!
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 06-06-2010, 04:27 PM   #13
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Oil both and use and outerwear pre-filter for big stuff. Take off the outerwear filter between rounds or every once in a while on practice and blow it off with the air compressor. Keeps everything super clean.
Something like this one.http://www.amainhobbies.com/product_...-8ight-T-Black
awdcameolsx is offline   Reply With Quote
Old 06-06-2010, 05:37 PM   #14
fukitol's Avatar
do that with my dirt bike why have i never done this to my rc.
is that fast, can i drive it, how much do they cost
fukitol is offline   Reply With Quote
Old 06-06-2010, 05:38 PM   #15
Trader Rating: 47 (100%+)
1) Use a good airfilter oil on the inner and coat the
ends with grease.
2) Use a thinner pre-filter oil on the outer.
3) Wrap the outer with self adhesive bandage.
4) Make sure you use zip-ties, 0-rings or hose
clamps to hold the rubber airfilter tube unto
the carb and filter assembly.
You will be suprised how the self adhesive bandage
catches so much dirt and still breathes so freely.
rageworks is offline   Reply With Quote
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
What oil can be used for air filter? catkchun Malaysian R/C Racers 16 04-26-2014 03:49 AM
