Old 06-03-2010, 07:19 PM   #1
whiskyshooter's Avatar
Default Truggy tire help
Hey guys I am looking for some help with tire choice. Right now I am running the proline caliber m3. Seems not 2 bad but wears out fast. The track I run on is a sort of a clay/sand base. The track will clean up to a hard pack with a light dust on the race line most of the time.
whiskyshooter is offline   Reply With Quote
Old 06-03-2010, 07:41 PM   #2
J.Sears's Avatar
Originally Posted by whiskyshooter View Post
Hey guys I am looking for some help with tire choice. Right now I am running the proline caliber m3. Seems not 2 bad but wears out fast. The track I run on is a sort or clay sand base. The track will clean up to a hard pack with a light dust on the race line most of the time.
I would try a set of soft city blocks or a set of soft grid irons they seem to work just about anywhere or the jconcept sevens would probably be a good choice.
J.Sears is offline   Reply With Quote
Old 06-03-2010, 07:45 PM   #3
Trader Rating: 12 (93%+)
Sounds like my track. Try the hot bodies megabites in soft with the hb pink foams. They are better than the dd or sevens. They hook up great and the wear is way better. people were blowing tires in like 1 race day soft because its pretty hard right now and i got 3 race days on super soft. I love them.
rcdude236 is offline   Reply With Quote
Old 06-03-2010, 07:52 PM   #4
Stubbs's Avatar
Trader Rating: 57 (100%+)
What is the outdoor temp in your area? Above 85-90, you may want to try M2 Calibers. You'll get better tread wear, and may not notice a significant decrease in traction.
My local track is red clay, hard pack, with light dust in the groove when dry. We try to keep the cushion somewhat moist between heats, but the groove stays dry. I've found that JConcepts Crosshairs blue (soft) compound has excellent traction, and outstanding wear. I've got twice as much run time on them as I do my M3 Calibers, and they're just beginning to show signs of wear. I'd feel very comfortable putting 2 or even 3 more race days on them before even thinking of downgrading them to practice tires. We run (3) six min. heats, followed by 20 or 25 min. mains at my track.
Cityblocks are generally a good all around choice (I have soft and med. in my tire bin), but the JC and M2 Calibers may work for you as well.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 06-03-2010, 10:38 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
I would try soft gridirons or j concept 7's. The 7's in the soft blue compound last a lotljnger than the m3 calibers ever did. The other thing you can dk to the calibers is when they start to wear down turn them around so they are running in the wrong direction. You will be suprised
JConcepts Truggy Tire Giveaway! AndyMoore Nitro Off-Road 64 05-07-2009 05:53 AM
truggy tire question forrestboy Nitro Off-Road 16 01-12-2009 02:55 PM
Pro-Line's new truggy tire. RMG Northwest Racers 22 06-18-2005 12:52 AM
