Old 06-02-2010, 04:21 PM   #1
Default 8ight t 2.0 rtr shock top caps and bottom caps
Is there any point in me upgrading to aluminum shock caps top and bottom?
I have noticed that the eyelits on the stock plastic top caps stretch alittle creating alittle "play".
What about the bottom caps. Do they wear?
Thanks.
bacchus is offline   Reply With Quote
Old 06-02-2010, 04:22 PM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
Thanks.
The top caps yes defiantly.
Old 06-02-2010, 04:35 PM   #3
sluggo_sx8's Avatar
why??
sluggo_sx8 is offline   Reply With Quote
Old 06-02-2010, 04:38 PM   #4
Frank L's Avatar
The plastic ones could strip and you might lose a cap in the middle of a race.
Old 06-02-2010, 05:24 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed! Get rid of the garbage plastic caps and get some real caps. I would go ahead and do the bottom too.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-02-2010, 05:26 PM   #6
8&stuff's Avatar
Trader Rating: 55 (100%+)
Originally Posted by sluggo_sx8 View Post
why??
because you can. aluminum caps wear out let alone plastic caps. the plastic bottom caps are fine.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 06-02-2010, 06:09 PM   #7
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
plastic caps are fine, they pop off if they have already been crossthreaded. an ally can rip in the same crash (never had 1 of those wrecks) and then you body's threads are a victim as well. pick ur poison and drive well.
just make sure no crossthreads or lose fitments on ur shock ends.
have fun
R
UltegraSTI is offline   Reply With Quote
Old 06-02-2010, 06:14 PM   #8
Not only can the plastic caps strip easily, the eyelets also oblong almost instantaneously, and they don't bleed the same, and they don't seal as well, and they don't tighten as well, and they cross thread super easy. They're just bad. Spend a couple bucks and get the aluminum ones. I guarantee you will be happy you did.
-Koby Kubrin-
Old 06-02-2010, 07:06 PM   #9
Registered User
UltegraSTI's Avatar
isnt there a mod to the caps that every1s jerkin off over? changin it to more of a 'tamiya theory' type shock.
R
Old 06-02-2010, 07:16 PM   #10
R
Yeah, the mod is to drill a small hole in the top of the cap to vent air behind the bladder. Then you use a small piece of dense foam to fill the void behind the bladder. Supposedly makes the shocks more consistent and easier to bleed. I have mixed feelings about it myself.
-Koby Kubrin-
Old 06-02-2010, 10:29 PM   #11
fallguy's Avatar
you could just ebay from a chop shop the whole pro shocks..
Hyper 9/MMM 2200KV/7955Tg
XR10/M2 DIG/7955Tg
MBX6T/Tekno V4/MMM 1800KV/7955Tg
Dnano
fallguy is offline   Reply With Quote
