Old 06-02-2010, 10:36 AM   #1
racing_jason's Avatar
Questions?? what pipe for torque
Right now I am running a .21 ninja with a 2035 pipe and I would like some more pop out of the motor. Restrictor wise I'm running a size 8.
Any suggestions will be helpful.
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 06-02-2010, 10:37 AM   #2
RC-ZOMBIE's Avatar
Thanks Jason
whats your clutch set up?
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 06-02-2010, 11:07 AM   #3
Rc8 clutch with hard shoes and 1.1 springs
Old 06-02-2010, 11:13 AM   #4
RC-ZOMBIE's Avatar
You should have lots and lots of pop. You could try a 2013 pipe, how old is the motor and do you have it tuned right on the low end? please dont take the wrong way just a question. Also how old are the springs and shoes?
Old 06-02-2010, 11:15 AM   #5
Trader Rating: 20 (100%+)
Thanks Jason
I don't no any pipe that can beat the 2035 feel on bottom and keep ur fuel mileage up and still have good top end power so if u need more pop maybe try a gearing change on the center spur gear and go up 2 teeth to get more snap.
Or u can get a 28. I'm surprized u need more power.
Matt Piva is offline   Reply With Quote
Old 06-02-2010, 11:20 AM   #6
RC-ZOMBIE's Avatar
Are you using a 16 or 17 tooth bell? The 2013 has way more bottom than the 2035 and about same on top same fuel economy maybe a bit more, But it also depends on the motor, clutch, tune, and gearing. The 2013 and 2035 are my favorite pipes!!
Old 06-02-2010, 12:00 PM   #7
jmaxey51's Avatar
the dynamite 007 pipe will give you tons of bottom but it may ruin run time.
jmaxey51 is offline   Reply With Quote
Old 06-02-2010, 02:27 PM   #8
The motor has about two and a half gallons through it the clutch set up has maybe 30 min of drive time (i cleaned it up about half way through that time period)
16/44 is what I'm geared at.
Tuning wise I had a guy help me tune it in.
What 2013 pipe is recomended?
Old 06-02-2010, 02:49 PM   #9
Torian4000's Avatar
Trader Rating: 49 (100%+)
+1 I use the 007 for short track applications but my max runtime drops to 8 mins vs. 9 mins with an 086 on my P5XT. The pipe will give you more than enough torque or "pop", if that's what you're looking for.
Torian4000 is offline   Reply With Quote
Old 06-02-2010, 03:12 PM   #10
RC-ZOMBIE's Avatar
Werks,Orion they are the same pipe just diff manufactures
Old 06-02-2010, 03:18 PM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
I would just try a long header on the pipe you are running. Like a RB 98mm long header or nova 41020 long header. That was always the ticket for me when I needed more bottom end.
Old 06-02-2010, 03:21 PM   #12
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Is this the ninja JX 21 or MR 21? If it is the JX, something is wrong. You should have PLENTY of bottom. Even in a truggy the JX has an overpowering bottom end. I would look more to tuning and clutch than the pipe. 2035 should give you the bottom you need.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-02-2010, 03:36 PM   #13
RC-ZOMBIE's Avatar
+2
Old 06-02-2010, 09:42 PM   #14
Trader Rating: 27 (100%+)
Racing Jason.....it's your gearing. I know your getting many different answers to your question but I assure you that the most obvious issue is your gearing. A 16 tooth bell will give you more top but totally kill the bottom end. And the 44 spear gear will also kill your bottom but give you more top. Base on your gearing your car is probably running like crap on the bottom. Go to a 13 tooth clutch bell and a 48 spur gear. If you're running the 2035 you should be set, the 2013 awesome as well. But your problem is your gearing.
Johnieblaze is offline   Reply With Quote
Old 06-03-2010, 03:33 AM   #15
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
his gearing is fine; 16/44 is the stock kit ratio for an RC8. The diffs are geared differently than most buggies so the 16 (or optional 17) tooth clutchbells are normal. You could go up to 16/46 if wanted.
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
BEST PIPE FOR RB BSC Nitro Off-Road 38 07-23-2008 02:46 AM
pipe for vspec spudly12 Nitro Off-Road 25 05-05-2008 10:22 PM
what pipe for V-Spec tonyy Nitro Off-Road 17 10-29-2007 09:16 PM
