Engine Wont start >
Engine Wont start
Engine Wont start
Old 06-02-2010, 06:17 AM
Bighomedog11's Avatar
Default Engine Wont start
Hey, I just got this nitro truck in a trade. I have not sent off my truck yet, because i want to make sure the truck he sent me runs. But i cant get it to start up...
I am not sure if the glow plug is bad. But when i put the glow plug igintor in the motor the motor does get warm. I am not sure if it not starting cause the glow plug..
But it wont start up for nothing. What are some advice/tips i should do to get it started? Because im really about to send him his truck back because it wont fire up
Bighomedog11 is offline
Old 06-02-2010, 06:22 AM
Madbrad's Avatar
Trader Rating: 30 (100%+)
1)Make sure your ignitor is charged up.
2) Take the glow plug out go the motor and put it in the ignitor and make sure it glows.
3)when the glwo plug is out, turn the motor over a few times in case it has been flooded.
4) Make sure the fuel you have is not old.
5) Prime the motor a little by turning it over and putting your finger over the exhuast untill you see the fuel in the line reach the carb.
Madbrad is offline
Old 06-02-2010, 06:29 AM
I have new fuel
I did the prime thing and i seen gas in the line
The glow plug ignitor is fully charged..
I will do the other thing to make sure the engine is not flooded..
But when i remove the glow plug and put it in the ignitor i seen alittle red glow on the plug. Not sure how bright it suppose to be though. And i also notice that the engine got warm when i had the ignitor on the glow plug.
So im not sure if the glow plug is the problem.
Old 06-02-2010, 06:48 AM
I agree check to see if its flooded ... and if you have a new Glowplug i would try it .. Mine glows pretty bright..
Tcaputo is offline
Old 06-02-2010, 09:31 AM
I got a new glow plug for it. I put it in and i put my finger on the stinger to prime it. And still no luck. I even removed the motor and made sure i got all the fuel out. I just cant get it to fire up for nothing. It has a fresh glow plug but wont fire up.
Old 06-02-2010, 09:34 AM
jmaxey51's Avatar
its probably way to rich. also did you try pulling the throttle some?
jmaxey51 is offline
Old 06-02-2010, 09:36 AM
Yes i tryed opening the throttle some.
I turned the High needle all the way in then i turned it out 2 1/2 turns
Old 06-02-2010, 09:37 AM
jmaxey51's Avatar
what about the bottom? most engines are about flush... what engine is this?
jmaxey51 is offline
Old 06-02-2010, 09:40 AM
Didnt really mess with that one.
but it is a XTM X-Cellerator
I think its a .12 or .18
Old 06-02-2010, 11:49 AM
DRKWNG's Avatar
What kind of Ignitor is it? The kind that you put a duracell battery in doesn't heat the plug element up enough to start some motors. Try a Hot shot or a Mcdaniel's and see it if helps.
That said this is just a guess.
DRKWNG is offline
Old 06-02-2010, 11:54 AM
jmaxey51's Avatar
+1
jmaxey51 is offline
Old 06-02-2010, 12:13 PM
No i have the rechargeable ignitor. I dont think the ignitor is the problem though.
Old 06-02-2010, 12:31 PM
Are you sure your piston goes up and down when turning the engine over? If it doesn't something in the engine might be broken (You should be able to hear the piston going up and down when turning the engine over)
Check out this video out I made for you: http://www.filefront.com/16630329/EngineStarting.MPG
helgso is offline
Old 06-02-2010, 12:40 PM
Thanks for the video.
Yes i hear my piston going up and down. Matter of fact i can see it going up and down when i remove the head and when i pull the string i can see the piston going up and down.
Old 06-02-2010, 05:26 PM
Here is a video i made of what is happening
http://www.youtube.com/watch?v=CO0jksD22O0
