Old 05-31-2010, 11:14 AM   #1
jeff_ellis_9's Avatar
Default had a runaway, now what?
When I was racing yesterday my Novarossi N21BF I bought used (but only 1 gal on it) ran away with me due to Rx loss of power (dead battery). I was up on the stand and I had to run down and get it to shut it off (on its lid). My concern is it sat there high revving on its lid while I ran down the steps and went to get it. Maybe around 10 sec max! I did manage to shut it off by plugging the exhaust.
My problem is now its being a pain to keep running. It would crank right up but then when you drive it about 20ft it would flame out. Then it would fire right back up and do the same. Even sitting on starter box running it didnt want to idle. Now this was my first time running this motor and my run away happened not long after installing the motor, so I can't say that the motor was in perfect tune from the get-go, but I can tell you it was at least going around the track. Do you think my tune got way off when I had the run away? Or is there something else I need to do/check?
I can't do to much now as I have to get another throttle servo (probably blown due to runaway stress) and a new Rx pack.
Also, one last question on run-aways, so obviously I dont want this to happen again, how can I prevent it? I fellow racer gave me a spring ("fail-safe") to put on the throttle side connected back to the HSN to keep the carb 'closed' if my battery dies again. Also note my radio is a spektrum DX3S
Thanks for the help in adv.
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-31-2010, 11:19 AM   #2
Lilja's Avatar
I used to use an old manifoldspring. It was strong enough to move the servo when the battery was dead, but on the other hand its alot of stress on the servo and its gonna drain the battery faster. How much I dont know but still.
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 05-31-2010, 11:19 AM   #3
Trader Rating: 12 (93%+)
Yes make sure to charge your pack and not run it for too long. As far as the spring use it! I use a rubber band but the springs work good too. this way when you look power it shuts the carb and no more run aways.
rcdude236 is offline   Reply With Quote
Old 05-31-2010, 11:30 AM   #4
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Engine sounds like it's toast.
You never want runaways, always make sure your reciever pack is charged and don't run more then 45 min on a good fresh pack. Sitting tinkering also kills the pack too.
Get gmk bands or little rubberbands and make a return spring on the carb. this way when the pack dies it should return. May not always... but most of the time it should. I never had a run away on one of my race cars.
Check if you radio has fail safes when you bind it. set throttle to neautral in fail safe mode.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 05-31-2010, 11:52 AM   #5
throttle return bands to me are much more important the a fail safe. I use both but the return bands have actually saved me twice.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-31-2010, 11:55 AM   #6
Yea failsafe is for the TX failing. Bands for the reciever pack.
Old 05-31-2010, 12:19 PM   #7
how can I check if engine is toast?
this motor is not old at all. just 1 gal
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-31-2010, 12:21 PM   #8
Cory Kerber's Avatar
It doesn't matter how old it is, it matters that it was ran Wide open throttle for an extended period of time. It sounds like it's lost its compression.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 05-31-2010, 12:53 PM   #9
merdith6's Avatar
Default Maybe not.
yeah it sounds not too good. Did you replace a glowplug?
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-31-2010, 01:22 PM   #10
Slider30250's Avatar
Try replacing the con rod in the engine, extended high revs can stretch the rod and cause the problems your describing.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 05-31-2010, 01:43 PM   #11
thenova70ss's Avatar
Trader Rating: 52 (100%+)
Yep what He said 100% Right. You need a new Rod and it should be Ok.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 05-31-2010, 01:45 PM   #12
any links please? for the con rod. Thanks
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-31-2010, 02:25 PM   #13
hdcruzer's Avatar
I really doubt if its you connecting rod. Thats a easy check, if it has little or no play its fine. More than likly that motor had a lot more than a gallon of fuel through it. Did you buy it from somebody you know, or was it just word of mouth? My guess is the sleeve is gone. Have it resized and you should be good to go for a few more gallons.
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 05-31-2010, 02:31 PM   #14
jmaxey51's Avatar
put a new glow plug in it, i have had a run away and it did the same thing and it was just a glow plug, i ran it for another 6 gallons after that.
jmaxey51 is offline   Reply With Quote
Old 05-31-2010, 02:37 PM   #15
^ I bought it from the guy that just replied, Jmaxey. But it ran fine when I first got it going. And I can tell by looking at the motor that it hasn't been used much.
But, keep in mind guys, I haven't had the motor running long at all to really get the temps up and get the tune exactly right. Im just telling you the problems I encountered after my run-away, BUT, could have just timed right that my tune was off.
Also, I forgot to mention, the fuel I was using I have had since about Sept last year.
hdcruzer, how can I check the play you are talking about?
oh and tried new plug
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
what is the best way to stop a nitro engine? lewis666 Nitro Off-Road 107 06-02-2014 02:37 AM
runaway car problems thinguy10 Electric Off-Road 10 10-18-2013 11:10 AM
