Old 05-31-2010, 06:17 PM   #16
No the motor never starter!! well technically what is broken idk but when i spin the flywheel, the cylinder moves, but at the beginning it makes a weird noise and for a while the cylinder doesn't move while spinning the engine... weird, but again there was never combustion in the engine
mf305 is offline   Reply With Quote
Old 05-31-2010, 07:03 PM   #17
2fst2c's Avatar
Trader Rating: 114 (100%+)
Are you sure the piston is not stopping at the top in the pinch and then the flywheel is slipping?
2fst2c is offline   Reply With Quote
Old 05-31-2010, 07:33 PM   #18
camocowboy's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to camocowboy
Default PM
You have PM. Doug if you have never dealt with Nova or fusion then stop posting about how its gonna work because you dont know.
#92 Greg Singletary
Punched R/C Productions - Ascendancy Racing - Byrons Fuel - JGO Paint - The Nitro Pit - One Hobbies Shop and INDOOR RACEWAY
camocowboy is offline   Reply With Quote
Old 05-31-2010, 07:43 PM   #19
houston's Avatar
Trader Rating: 91 (100%+)
first off , have you preheated the engine? do you know what you are doing when it comes to running these engines? i agree with earlier poster that what you are feeling is the metal pinch between the piston and sleeve . these engines require a lengthy break in process .
so in closing i doubt your engine is "broke" but rather in need of service from a well versed nitro guy
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-31-2010, 08:01 PM   #20
excuse me are you calling me dumb?? sorry no offense but i have a bunch of engines and many more novarossi's and i know how to break in an engine, it isn't normal, the piston and the crankshaft are directly attached if the sleeve rotates but the piston doesn't move for about 20 degree spin the motor is broken. Or am I missing something?? I could be wrong...
Old 05-31-2010, 08:07 PM   #21
houston's Avatar
and how are we supposed to know your experience level?
when posed with the questions you asked , i would assume that you are a nitro novice and just because you have a lot of nitro engines by no means make you an expert
hope you get it all worked out , if there is indeed a problem with the engine from the factory , it will get taken care of GUARANTEED , if it is your fault you will have to pay for the repairs
Old 05-31-2010, 08:12 PM   #22
RCmayor's Avatar
Send a message via Yahoo to RCmayor
The sleeve is in there pretty tight, nowhere for it to rotate. Shoot a video of what you are seeing and post it. There will be a point at TDC where the piston wont move but the flywheel will rotate back and forth quite a bit.
RCmayor is offline   Reply With Quote
Old 05-31-2010, 08:12 PM   #23
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
what you are saying makes no sense.... the sleeve does not rotate... the crank does which causes the piston to move up and down on the connecting rod....if the piston is getting stuck top dead center the piston will not move for 20-40 degrees while on top dead center but the crank and rod you will see move.... but not the piston... the sleeve will never move in an engine unless the head is loose...... some picks might help out if you can post them.... remeber we are all just trying to help you out..... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 05-31-2010, 08:30 PM   #24
Thank you, ya when i rotate the crankshaft it doesn't make a normal noise, and the crank rotates for a bit without the cylinder moving, is that normal? I don't want to send the engine back and it's alright. Please let me know, i think that the piston is loose a bt from the crankshaft, so it can move a little bit.
Old 05-31-2010, 08:31 PM   #25
losi_racer's Avatar
Trader Rating: 25 (100%+)
Ill post what ever i want greg. I made it clear that novarossi may be different but i have delt with sending an engine to a manufacture due to an issue, and with all race engines, they do not carry Warrantys so unless they wanna be great on customer service they dont have to do squat
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-31-2010, 08:48 PM   #26
smokinu's Avatar
Trader Rating: 60 (98%+)
lmao, this guy sounds like a total Newb,
Douglas, Calm down, Novarossi is pretty good when it comes to customer service, though they are not hitec! they try to keep there customers unlike some companies.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 05-31-2010, 08:51 PM   #27
dude if you just want to come a criticize me get the hell out... First off everyone has to learn... second I bet you may know a lot about rc cars, I know more about other things. so please this thread is to help Shut up dude
Old 05-31-2010, 08:52 PM   #28
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Sounds like a certain Japanese engine manufacturer to me. OS engines maybe??
I'm with Houston on this one. You don't sound very experienced with nitro engines. Is there maybe someone more experienced you can show the engine to? It sounds to me like you may have a normal new engine. The piston will rotate easily for the first bit of the stroke until it hits the "pinch zone". At this point you will feel a lot of resistance.
As Jer said, the Cylinder will Not move at any point.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-31-2010, 09:03 PM   #29
losi_racer's Avatar
as thats what i was trying to explain, im not sure how they work they could be great
i got them to replace parts
Old 05-31-2010, 09:40 PM   #30
chuckinator's Avatar
Douglas what I think they are trying to say is if you haven't delt with or have any idea on a certain subject, its best to keep your mouth shut before you make yourself look like a total idiot.
But feel free to post whatever you want.
Chuck Hicks
TLR, Novak, Proline, Spektrum, Horizon Hobby, shortcoursehobbies.com, SPY optic, Competition Hobbies
chuckinator is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Mugen MTX-2 tekrsq Nitro On-Road 2839 10-15-2006 08:09 PM
