Old 05-31-2010, 10:24 AM   #16
Trader Rating: 61 (100%+)
+1000 on lucky 7 ...its the bomb ....i only seal motor that have strange tuning issues ...but the good thing about lucky 7 .....you just paint it on and you golden
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 05-31-2010, 10:38 AM   #17
jeff_ellis_9's Avatar
Ok. Anybody else for bearing removal? And how do you take the piston out?
But question is, is it ok for air to come out around the bearing? And/or how can you tell when that bearing needs replacing?
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-31-2010, 10:51 AM   #18
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Ya,the front bearing it might blow a little air since there isn't any oring sealing the bearings, just the seals on the bearing. How old are the bearings? The front bearing takes a beating because it gets slammed against the starter wheel so much. So I would replace if it is 2-3 gallons old.
RCmayor is offline   Reply With Quote
Old 05-31-2010, 11:03 AM   #19
well the motor I bought used and they guy said it had just been broke in with about 1 gal on it.
how can you tell if it is worn? Or can you? just kinda go by # of gal
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-31-2010, 11:07 AM   #20
Jaz240's Avatar
Trader Rating: 52 (100%+)
My advise would be to find someone to help you in person. This is not something that can be done via the internet. Changing bearings and disassembling your engine for the first time without someone present to help you will more than likely lead to you damaging it and then the entire thing may be ruined. Go to your local track and ask for help. Even if you need to offer someone some money to help you it will still be cheaper than having to replace your engine
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 05-31-2010, 11:42 AM   #21
RCmayor's Avatar
You really can't, if it is indeed 1 gallon old it is probably fine. What makes you think it is bad beside it leaking when you blow into the engine? If the engine is ran rich on the bottom needle the bearing could seep a little oil. This doesn't mean it is bad.
Old 05-31-2010, 01:56 PM   #22
nothing makes me think the bearing is gone. Im just curious for when that day comes
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
UNDERSTANDING SERVO'S DIGITAL VS ANALOGUE COBRARACING Nitro Off-Road 20 01-01-2010 10:20 AM
Leaking nb16 vitor Singapore R/C Racers 21 10-07-2006 11:45 PM
