Originally Posted by bacchus
La. I was the guy with the losi rtr truggy at Springfield. I think it was you and I talking about glow plugs.
Ha HA. i knew it was you. Hey, just plug your exhaust and carb and clean your engine with some simple green, water and a toothbrush. Try to keep water away from the front bearing. I dry it off real well with a heat gun and then break it all down and check everything.
GOing to a track this weekend in mobile then i will probably be in watson the week after to try the new track
I also figured out why i was having problems in my main last night. I had broken clutch springs and did not realize it till i got home.
