Old 05-30-2010, 03:49 PM   #1
jeff_ellis_9's Avatar
Default Which receiver pack? (losi 8ight)
Whats a good receiver pack to use in the 8ight buggy? $$ plays a part here so whats something that should at least get me by? I know LiPo is a good route to go, but whats my cheapest in those going to be? <----would also need a charger.
Or, is there some good NiMh packs that hold up good? I have had ProMatch 7.4v stick packs before and they held up good, think their receiver packs would also?
I was racing today and my losi nimh receiver pack (old) gave me trouble with staying charged. So im just looking for something that will do me good on a race day.
thanks alot
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 05-30-2010, 03:56 PM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
I have had good luck with the trinity IB or EP nimh packs when I used them. I use a losi lipo now and it's far superior. I don't even see the trinity packs listed but j have also used the team Orion pack and it worked well too. Here's a link
http://carolinasrc.com/webstore/scri...idproduct=1828
this pack looks good to
http://carolinasrc.com/webstore/scri...dproduct=14809
Old 05-30-2010, 06:35 PM   #3
what about this one?
http://www.promatchracing.com/proddetail.php?prod=1612
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-30-2010, 08:23 PM   #4
Also, what chargers can be use for what packs (NiMh)??? Im looking at maybe getting the Promatch 5 cell 1600 mah pack.
for instance, could I use a Traxxas receiver charger for that Promatch pack, or the ones linked above? The traxxas charger reads 3-4 hour charge time with 1200mah. even though the charger says 1200mah, can I still charge the 1600 mah packs with it?
reason I need another charger is my Losi charger has only one charge plug, the small red one, NOT the J type. I need a charger with the J type plug
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-30-2010, 09:55 PM   #5
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Honestly I'd say any good 1500-1600mah NiMH pack is fine.
Regardless you're going to get about 1hr or so of run time out of them.
I was running a lipo RX pack but, even though I had a Losi LVC on it, it ate my KO Propo RX. I honestly only got a few minutes more run time out of it, so it really wasn't worth it. I'll stick with NiMH especially since I got a few 1600mah packs on clearance from AMain for $7/ea.
heavyjeffd is offline   Reply With Quote
Old 05-30-2010, 10:04 PM   #6
you think the traxxas Rx charger would work good?
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 05-30-2010, 10:05 PM   #7
Cory Kerber's Avatar
Get yourself a good charger that can do it all. You'll be glad you did.
Here's the best bang for your buck.
http://www.xheli.com/thac6bachwac.html
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 05-30-2010, 10:06 PM   #8
Trader Rating: 12 (93%+)
The associated battery is a good battery. i have two of them and i use them for my hb d8 and they have never failed me. I can run a whole day of racing w/o recharging. That is the 3 6min heats and the 15min main. But i usally charge after the 3 heats.
rcdude236 is offline   Reply With Quote
Old 05-30-2010, 10:17 PM   #9
KWT-NITRO's Avatar
hello,
i used 2 of this pack all season long with no issues,
http://www.amainhobbies.com/product_...-Losi-8ight-20
i never use a fast charger for any NIMH packs, i use a normal JR charger (the one that comes with any airplane TX) i charge them 12 hours before the race, i use one for the quals while the 2nd is charging and for the 45min Amain, i put the newly charged one. our Nats Final was a 60min race, still no issues.
hope this helps
cheers
ALi
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 05-30-2010, 11:00 PM   #10
Frank L's Avatar
These packs like to be charged at 1.0-1.5 amps. Look at the output of the traxxas charger and see what it is. Lower amp rating is ok but it will take longer. Higher will overheat the pack and nimh packs do not like heat.
Originally Posted by KWT-NITRO View Post
hello,
hope this helps
cheers
ALi
Man Ali thats a monster pack that should last aaaaaaawhiiiiiiiiiile.
Old 05-30-2010, 11:11 PM   #11
merdith6's Avatar
Default yes
The IB1600 packs are great. Am Main has the pro tec ones for about 20 bucks. I've never had one die on me, Dynamite makes them too, and trinity. I found one on ebay at rc mall for like 17 bucks shipped...but I do charge them before I use them of course. and like the above said, 1-1.5 amps is perfect. I charge mine at 1 amps. The faster you charge a nimh battery the more volts it puts out, but it will drain faster, makes sense right, and if during the charge it gets hot then stop charging it and let it cool off before finishing a charge, and the first charge it never hurts to repeak it once between cooling.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-31-2010, 12:05 AM   #12
KWT-NITRO's Avatar
LOL Frank, i just wanna make sure everything is good to go, not to forget that a 60min Amain last aaaaaawhiiiiiileee as well
cheers Bro
Ali
Old 05-31-2010, 05:44 AM   #13
RacerScott's Avatar
hello,
hope this helps
cheers
ALi
That pack has to weigh alot!!
I use a 1200mah lipo. I ran a 25 min main and after the race it took 330mah. So it could do a hour easy.
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi 8ight T Race Package boatsnhoes R/C Items: For Sale/Trade 6 10-23-2009 12:43 PM
team losi 8ight truggy pro loaded with the best tony oh boy R/C Items: For Sale/Trade 15 05-05-2009 09:32 PM
Must see this combo... Losi 8ight, RB C6, plus more Mike Elam R/C Items: For Sale/Trade 10 07-30-2008 12:23 PM
