Old 05-29-2010, 03:39 PM   #1
Trader Rating: 1 (67%+)
Default Need help w/Picco/Ofna .21
I have a Picco/ofna .21 engine that is in a Tmaxx. I can't get it to stay running. It finally started after a new glow plug and it runs for a bit and then dies. I think that the tune on it is way off. Does anyone have a manual or at least know the out of the box settings for the high and low speed needles?
mbogosia is offline   Reply With Quote
Old 05-29-2010, 07:33 PM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
Refer to the link below for what should be your engine manual; containing baseline needle settings.
Good luck.
http://ofna.com/pdf/picco21max.pdf
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 05-29-2010, 08:51 PM   #3
Huge help! Thanks. Previous owner had the main needle at 2 turns out. I manged to get it idling great with it 3 turns out, but it would stall with a touch of the throttle.
Old 05-29-2010, 10:16 PM   #4
mblgjr's Avatar
Ok, so have you read the instructions and baselined the carb; then run again?
Glowplug and fuel choice can also cause running issues.
What are you using for a glowplug right now? McCoy #8; or #59; or Odonnel 77, 88, or purple sport plugs should get you going.
Old 05-29-2010, 10:29 PM   #5
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
If it stalls when you touch the throttle, then your low-speed needle may be too rich.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 05-30-2010, 04:19 AM   #6
Well, I can't say what plug was in it originally. I bought and installed a O.S. #8. The description for it said it was a medium plug for 1/8 scale offroad engines. As far as fuel I am not sure what the PO used, so I am using Byrons 20%. I will mess with it some more today and post back up.
Old 05-30-2010, 07:28 AM   #7
Well I am still stuck. It starts and idles, and then starts idling really fast after about 20-30 seconds. There are a lot of air bubbles in the tank and the line. There is no telling what is wrong with this thing.
